Question about Frigidaire Dishwashers
A inch of water stays in the bottom of my dishwasher before and after running the dishwasher
    Champion:
  • 245 Answers
Check to see if you have an obstruction in your drain line, or make sure you have a lift in the middle of your drain hose.
Posted on Aug 19, 2010
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
After running a cycle there is still abount 1 inch of water left in bottom of dishwasher. What can it be and how can I fix it?
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 15, 2010 | KitchenAid Dishwashers
I have a 17 - 18 inch dishwasher and the water runs out before the wash cycle is over. If I have not used it for a while, when I open it there is water in the bottom. What am I doing wrong??
I think your drain hose must be too low...the drain hose has to raise above the bottom of the sink..this keeps a air gap in the hose.. keeps the water from running out and will also keep water from the sink running into the dishwasher... let me know if this helps
Sep 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Water stays in the bottom of dishwasher after cylcling
If the water is clean and only about an inch deep or less, this is normal and almost every dishwasher keeps some water in the bottom to prevent the seals / gaskets from drying out.
If the water is not clean and there is an odor, please report back here and we can take the next step. Is so, please note approximately how full of left over water the dishwasher is. OK?
Aug 03, 2009 | Dishwashers
JET TECH/model F18/small amount of water stays in bottom.Wont fill or cycle but water runs.
It is normal to have 4 or 5 inches of water inside the dishwasher unless you remove the stand-pipe (located inside, front right side). This pipe should be removed at least once a day and the dishwasher should be drained. Don't forget to turn the power off first.
For more info goto to
http://www.mvpgroupcorp.com/jettech/support.htm
Robert
May 11, 2009 | Jet Tech Systems 24 in. F18DP...
Water in bottom of dishwasher
Either run the dishwasher or set it to the "drain" cycle
Apr 27, 2009 | Dishwashers
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
