Question about Electronics - Others
Tascam tm-d4000 error code 99=00000004-00 whats wrong
4 Suggested Answers
  • 5125 Answers
SOURCE: Hi I have a tascam tm-d4000 it stopped working now shows on the screen "fatal error"
Usually, this is a symptom of a main board failure. Sometimes rebooting the mixer will temporarily stop the error. If there are any additional numbers (like 99-00000009-00) in the error message, you can try resetting the unit. Press and hold Shift and Mixer Position and then turn on the Mixer. The unit will need to be professionally serviced or replaced. Since it is a discontinued model, check your warranty. It may be cheaper to replace the mixer.
I wish that I had better news for you.
Posted on Jan 28, 2015
  • 3368 Answers
SOURCE: I have a mixer tascam tm-d4000 and stopped working now screen shows "fatal error" can you tell me how to fix it please
Do you have the service manual and the necessary tools and experience? If not take it to a service shop it will be more cost effective.
  • 293 Answers
SOURCE: I have mixer tascam tm-d4000 stopped working now shows on the screen "fatal error" what I have to do
I'd suggest flashing the onboard CMOS and check for updates. A fatal error is usually caused by corrupted programming on these units. If you're not comfortable flashing the CMOS I'd suggest taking this unit to a service and repair professional.
Flashing the CMOS is relatively easy. Take off the bottom cover and you'll see a ton of wires and a control board and the back end to the main computer unit. Open the secondary case up and look for a watch battery on board. Pop it out and let the unit sit for awhile (10 minutes to an hour). This is usually a good time to buy a replacement battery. Once you've got the new battery pop it back in and it should brought the unit back to a factory reset state. Any stored programs will have to be reprogrammed but the unit should work. If you still get a fatal error it might suggest hardware failure. Some of the newer models of the Tascam series mixers (including submodels of the TS4000 series) have a hardware diagnostic that is available, while some of the simpler units just give you their version of a blue screen of death. Which could indicate anything from a lose connection and an error reading a subcontrol, to a blown capacitor, blown fuse, short circuit. If it's still under warranty I'd speak to the manufacturer about getting it repaired. They might also offer more sufficient troubleshooting over the phone for your issue.
I do believe there is a factory reset button code you can also try for this unit, but in my experience this doesn't really clear the memory and reset the unit properly. It's like a warm reset instead of a proper reset.
Jan 28, 2015 | Tascam Audio Players & Recorders
Jan 28, 2015 | Office Equipment & Supplies
Tm h6000II
I guess it lacks either a thermal roll or something's wrong.. like.. error code? check your printer software, usually displays an error code or says what the problem is
Jul 24, 2013 | Epson TM-H60000II Thermal Printer
How do I initialize the SRAM in my tascam tm-d4000? and How do i fix my 99-00000009-00 fatal error on my tascam tm-d4000?
if you keep Shift+Fader position pressed while turning the TMD4000 on, it will boot in Diagnostics Mode where you will find a menu to reset to factory default, and many more options,...hoping to be helpfull
Jul 05, 2012 | Audio Players & Recorders
I have a tascam dr7 with a device error 2 code...I used a 5v power supply not from tascam for quite a lot of time.....it eats batteries like crazy. Device error 2...what is it?
Device Error [2] is "memory bus error". There is nothing that you can do to fix it. There are two PCBs in Tascam DR-07. This is the bigger one that has LCD display and all control buttons. Your best bet is to find a broken one that does not power up at all (the smaller PCB - which host the CPU - is bad) then swap the PCBs.
Dec 16, 2010 | Tascam DR07 Digital Voice Recorder
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Electronics - Others Logo
337 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
