Question about Sony KP-51WS500 51" Rear Projection Television
KP51ws500 turns green and shuts itslelf off
I have a KP51ws500 and the tv will flicker green and until it turns completely green and turns off. It also has blue curved lines on the screen. Any help would be great.
Thanks,
  • 5 more comments
  • chefcrw May 11, 2008
    Yes I have this same problem. The picture will fade to green then cut off or flash green and cut off. I've had this problem for over a year know is there anything sony can do to fix this. I spent slot of money on a product that is to be a great company. Thanks
  • Anonymous Jun 11, 2008
    I have the same problem also - turns green and shuts off. Any luck using the solution offered?
    Same problem here. The tv does not cut off, though. We can still hear the program, it is just all green.
  • Anonymous Sep 08, 2008
    HI - same deal- flickers green with line and then shuts off by itself. My hubby trying to fix it himself. It seems to help and works for a while if we shut the TV and let it cool down. Has anyone at all solved this problem yet?
  • jnroper28 Feb 22, 2009
    i have the same problem with green flash and then off what do the potentionmeters look like
    what do potentionmeters look like?
  • bigfreakyguy Mar 02, 2009
    Our TV can turn any of the colors before it turns itself off. started with green, but now, sometimes blue flicker, then off. sometimes red flicker, then turns off.
    We are ripping the thing apart right now. anybody help?
    Problem Solver:
  • 4 Answers
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
Posted on Aug 09, 2008
THIS WORKED GREAT! We bought this TV on craigslist and got home and the TV went out...I was furious! I came across this post and my boyfriend fixed the TV in less than 10 min!!! EASY FIX!
Posted on Aug 06, 2009
I did the same to mine. Readjusted the power voltage to each gun. Before we could plug up the red gun power, picture would look perfect absolutely perfect for about 15 sec, then it would go solid red. Now it looks perfect again !
Thanks to all who suggested redoing the power voltage to each gun !
Posted on May 21, 2009
This works!!! I did this when a friend of mine gave me this tv...I slightly turned all three bottom screws and the tv works like new..
Posted on Mar 06, 2009
  • markmills31 Mar 06, 2009
    Here is a link w/Great pictures.....
    http://www.somelifeblog.com/2007/06/sony...
Same thing was happening to ours...
Open the back.... With the TV on we tapped on the black rim of the green tube in the back and then it flickered several times. The tv stayed on though for once so we left it for 2 hours or so and tapped several times again and the green tube kept flickering really bright and turned off I think. We turned it back on and it worked fine - amazing - we were about to haul it to the trash!
Posted on May 17, 2008
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Sony TV Model No. KP51WS500 flashes green & turns off
yes u will have to get a expert in but here is a guide to help your tv is going into protect mode if the screen is flashing green with white lines in it its likely that the green tube is faulty this is very expensive & u my want to purchase something else.
Apr 08, 2010 | Sony KP-51WS500 51" Rear Projection...
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Picture flickers
Check your power supply. Is it plugged in to the wall or a powerstrip? You might be overloading the powerstrip. Could be a source signal problem. Does this just happen when watching cable TV or does it do it on dvd's as well? Through the PC it is probably the viseo card,try reducing the resolution output from the computer.
May 26, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Sony kp51ws500 television that turns on for about 10 seconds before the screen briefly turns green and then shuts off. The timer/stand by light flashes when this happens. Any insight would be...
Like all sonys you more then likely have a bad green tube ,disconnect CRT board off neck of green tube if set comes up playing shorted tube.ThankYou for trying FixYa. Have a Nice Day.
Feb 18, 2008 | Televison & Video
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Overheating problem??????
Jan 08, 2008 | Sony KP-57HW40 57" Rear Projection...
Green tube goes out
Dec 27, 2007 | Sony KP-57WS500 57" Rear Projection...
SONY KP51WS500 bought Feb. 2003 from Circut City
possible clod solder connection in the scan b+ voltages,contact sony and get them to check their dealer store locations in your area and have them send a message to the dealer describing your fault to them also.
Aug 06, 2007 | Toshiba 43H70 43" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
529 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
