Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Can't get login asus wl-520gu page when i type in http 192168
    President:
  • 357 Answers
Try using http://192.168.0.1 to get to the log in page of your router. The username should be: admin and password is either: admin or (no password). If this does not work, there is a reset button located on the back of your router, press this button and hold it for about 10 seconds while the unit is on, then try going to that address again.
If this still does not work, look on the bottom of your router or on the box which your router came in or the manual that came with the router. Check that you are trying to go to the correct IP Address. It should be located on the router itself, although, the standard IP Address for most routers is 192.168.0.1
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Posted on Aug 19, 2010
192168 01 login
Pam- Have you connected directly via ether net cable when attempting to connect to that IP?
Jul 29, 2014 | Motorola Computers & Internet
I cant reset asus rt-n10e routr
I had same problem with my asus device. so i called Asus Tech Support At Toll Free Number 1800-585-2494 and they have fixed my problem.
Hope they will help you as well.
Jan 20, 2013 | ASUS WIRELESS ROUTER |WL-520G - RT...
I lost my installing CD - ROM and my equiment is Asus WL-520GC/WL-520GU , can u help me? anyway, i cant even install my wireless equitment
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 29, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I can't log in to my router's web interface. I've tried the password as both admin and leaving it blank while the username is admin. The IP adress I'm using is192.168.1.1 and the ASUS router model is...
if you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
Jan 04, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I forgot me password for an Asus WL-520GU wireless router, how do i make a new one or change it?
Hi Dillon,
Please let me know what password you have forgotten,do you mean the one which is meant for log in to the router. open your browser and type 192.168.1.1 enter it and then check for the password.
Regards,
Gary
Dec 29, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Problem with Asus WL-330gE configuring page
Did you connect the device to your PC using the ethernet connector and power it up using either the USB or power adaptor? Those two cables have to be connected between the ASUS and your PC before you try to access the admin page via your browser.
Jan 07, 2010 | ASUS WL-330GE 802.11b/g Wireless Access...
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can´t login to my router
Try this website:
http://www.xbitlabs.com/articles/networking/display/asus-wl600g.html
They have a lot of info on this router. On page 6 it talks about the different ways you can access the interface. This may help you get in there.
Thank you,
Mike
May 11, 2009 | ASUS WL-600g Wireless Router
Computers & Internet Logo
836 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
