Question about Freezers
My upright freezer has alot of frost buildup on the shelfs. why?
  • Freezers Master
  • 1,250 Answers
Usually caused by an air leak due to the doors not closing and sealing around the frame of the door. look there first.
Posted on Aug 21, 2010
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Frigidaire upright model ffu21k2cw1 frost on top shelf and not cooling properly
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216802800en.pdf
Your unit is not self defrosting so I would suggest you do a manual defrost and see if it corrects the problem.
Also make sure that you have good air flow across the compressor.
Jan 01, 2012 | Frigidaire Freezers
Coil in top of freezer and top shelf in freezer have very large buildup of ice, melted it out but it soon froze back over
Good day,
I assume this is a conventional freezer, not a frost free model.
That condition is caused either by a loss of refrigerant or an internal restriction in the sealed system.
Both are, I'm afraid terminal, unless the machine is under 5 years of age, in which case it would be covered by factory warranty.
Sep 05, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frost Buildup on Top Shelf lower shelves aren't freezing
This link might help you troubleshoot
Freezer Frost inside Symptom Diagnosis Sears PartsDirect
The lucky solution is if the door seal or inner plastic liner need to be placed/repaired (this lets warmer air into the freezer causing frost and poor cooling).
But you can also see from the link that your symptoms could be caused by other electronic related things...more of a challenge to fix...
Helpful?
Good luck on your troubleshooting
Feb 17, 2018 | Frigidaire Freezers
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
