Question about Skil 623705 38" Corded Drill
The on off switch don't work. Where can I get it repaired?
  • 90 Answers
Look for a local tool repair shop in your area. they will have the switch or can order it. try partsdirect or replacement parts on the net.
Posted on Aug 30, 2010
Testimonial: "Yes thank you"
Front wipers don't work
Take it to a repairs shop,if you have to ask
& have no auto experience
Jun 26, 2013 | 2005 Ford Escape XLT
Repair intermittent switch on dewalt 20 Volt impact driver
Unfortunately Dewalt switches are solid state, meaning there is little to nothing you can do to fix them when they don't work. Occasionally spraying them with electronics cleaner and blowing them out with clean, dry air will make them work a little longer but more often than not you simply have to replace the switch. The part number for your driver is N084669. They cost between $65 and $75 so shop around or check with a local repair center.
Oct 23, 2012 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
Car will not come out of park
The park lock safety system gets power from the brake light circuit, this means unless the brake lights work and the pedal is depressed the system locks the shifter in the part position. The first thing you do is check the brake lights, if the lights work you have other issues best left to the dealer if the brake lights don't worth then you have found the cause and just need to repair the brake lights, this can be the brake light switch or the wiring connector to the switch. Repair as needed.
Oct 03, 2012 | Dodge Magnum Cars & Trucks
2005 DODGE MAGNUM WINDOWS DON'T WORK
chec fuses--there are some in engine area too--the main switch or the convenience module could have issues--get a repair manual or library has an auto section
Mar 02, 2012 | Dodge Magnum Cars & Trucks
Canon SX30: The zoom function that used to work. Now it has become unpredictable. Sometimes pushing the zoom lever gets no response. Other times after it has zoomed out it immediately goes back. ...
I was initially going to say this sounded rather like a switch error but I'm thinking this is a motherboard problem inside the camera.
A switch will either work or not. When they break they tend to stay in the on or off mode or in this case zoom or not. The fact that the camera is unzooming itself suggests to me that there is a signal or command if you will coming from the main board. I'm curious if the camera will even take pictures as this almost sounds like behaviour I would expect to see when turning the camera on.
Unfortunately I do not see any other option other than sending it in to Canon for repair. If you have warranty they will of course repair or replace the boards inside or even the switch. If you don't have warranty you need to be cautious about any repair costs. The camera is selling for about $450 and depending on what needs to be done and if Canon is offering a flat repair fee for this now then you can get them to fix or replace it. I've not had to replace a board in this model so I don;t know what the cost would be. It can be more than the camera is worth which is why you need to be cautious.
I've used Canons all my life and Canon support has always been fantastic. So I would call the store you purchased and see if you have any warranty either extended store warranty or just Canons. They will probably know if Canon has any repair deals but I wouldn't hesitate to contact Canon support. They may ask you to try a few things over the phone before sending it in. Make sure you ask about any fixed repair fee if it is available. If not keep in mind the repair verses replacement cost before spending any money. I don't work for Canon but have used their cameras for years and anytime I have had problems they have always done more than I expected. A couple of examples was asking about a driver for a used camera and they sending a new driver cd at no charge. They even repaired a camera that was just out of warranty at no charge. Canon will treat you right so don't hesitate to call them.
Sep 24, 2011 | Canon PowerShot SX30 IS Digital Camera
My sony wont switch on i tried charging it but nothing happens the screen does not switch on what should i do
You should try to replace a brand new battery. If it still don't work, then take it to the Sony repair centre.
Sep 06, 2011 | Sony Network Walkman NWZ-S545 Digital...
When i put ma ps3 on it goes green yellow red
I experienced the same issume before. This is called Yellow Light of Death or (YLOD)
Please see below on some information regarding this issue and some possible reslotion to prevent this from happening:
If we go by Sony's definition then having PS3 YLOD means "general hardware failure". So it means that a fault could have occurred anywhere in your Console. Don't be afraid though, since most of the times PS3 YLOD is due to motherboard getting detached.
Tips on how to fix it:
Alternatively you can try to repair ps3 YLOD yourself. There are a couple of things you can try to fix YLOD - check for any loose connections since some connections might be loose, you can also try switching it off for around 30 mins and switch it on again. This will help in cooling your PS3 down.
If these tricks don't work, then I will suggest you go through a dedicated PS3 repair guide instead of tinkering on your own. Such guide will cost you almost nothing in comparison to what Sony charges. And, god forbid, if it happens again you can solve the problem for free.
One of the greatest thing about doing it yourself is that you don't have to pay hefty charges to the big companies. Also, you don't have to wait for weeks, you'll completely fix ps3 ylod in no more than a few hours. Many people have already successfully fixed yellow light of death and I don't see a reason why you won't be able to do it. If my PS3 has yellow light of death then I won't pay Sony to repair my PS3. I'd rather fix PS3 lights myself.
If all this steps wont work i suggest to call SONY
1-800-345-7669
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
Nerdierob
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
Our 07 Acadia has power liftgate. It works fine with the keyfob or the switch on the dash, but it will not open using the outside handle on the liftgate. Do we just need to replace the liftgate release...
it sounds like the handle release switch is bad.you could replace it your self as long as you have alot of patience and don`t bend things to do the job.if not then check for a price at a repair shop if you don`t want to go to the dealer.
May 09, 2011 | GMC Acadia Cars & Trucks
If i have on the display PH, Toaster don´t
The problem was in the switch under the upper shield, the switch was broken. So Thank You very much for Your support. Best Regards, Jan - Czech republic.
Jan 12, 2010 | Roundup VCT-2000 Toaster
1995 Subaru Impreza wagon - heater fan
Mine use to work on high only. It was the switch cylinders, something like that. It was an easy fix. Now my blower motor works intermittently. If I kick it, it turns back on. It is located on the passenger side close to the door side directly above your feet (below the jockey box). Kick straight up. If you need to replace it it is also an easy do-it-yourself repair. Make sure before you go out and replace your blower motor that you check your switch. A lot of repair shops will replace the motor w/o checking the switch, you end up paying for 2 repairs. You can make sure it's not the switch by jumping (bypassing) the switch.You apply jumper wires (not cables) directly to the motor, if the motor turns on you know it's the switch.
Jan 01, 2009 | 1995 Subaru Impreza
Skil 623705 38" Corded Drill Logo
69 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
