Question about Kenmore 62802 Electric Dryer
No heat out hose of dryer no clog - Kenmore 62802 Electric Dryer
    Novelist:
    Champion:
  • 266 Answers
Sounds like your heating element or fuse is bad. If the dryer runs normally just no heat it is usually one of these. First make sure your breaker is on and you are getting 220v to the dryer. Try turning the breaker off and back on and then try your dryer again. If you have a volt/ohm meter it will be a great help in testing parts. You can get an inexspensive one at a hardware store between 10 to 15 dollars. It will come with instructions and I will guide you thru it. First unplug the dryer and pull it out you will need to remove the lower panel off of the dryer. It covers nearly the entire back and is held on with 5/16 screws. After the back is off you will see a metal encased heating element on the right side of the dryer as you face the back. At the bottom of this casing you will see two wire terminals with two wires connected to it. (some have two wires on one of the connections and one wire on the other) Remove the wires by pulling them off they can be very tight so grab them with some needle nose plyers on the metal connector not the wire and pull hard. If you have a volt meter you can put it on the ohm scale and hold the wire leads to the heating element terminals. Put one side on and then watch the meter as you touch the second lead to the other terminal the meter hand should peg out or if it is digital read a high number. If you do not have a meter you can remove the element there is a 5/16 screw holding it on one end and a slot it fits into on the other. Remove it from the machine and look up inside you may be able to see the heating element broken. Remove the screws holding the element to the casing and slide it out look closely at the element sometimes the break is hard to see. You may even have to shake the element to get the break to open up. When an element heats up a break will pull apart. If the element is bad replace it. If not your thermal fuse is most likely at fault. The thermal fuse will be connected to the heating element by a wire and will be located on the back panel (not the outside panel you took off but the back you exsposed when you removed the outside panel) center bottom to slightly center bottom right. It will have two connectors on it and be flush with the back and may be held in place by a rivit instead of a screw. If it is a rivit you will need to drill it out or shear it off with a chisel or screw driver tip. You can check it with you ohm meter by touching the terminals just like on the heating element. If not you can use a paper clip and put the two wires together that are connected to it. Reinstall the heating element if good and try your dryer. Temporarily you can leave the back off just run the dryer for 2 to 3 minutes to see if it gets hot. If it does replace the thermal fuse and you are ready to go. It is tempting to just leave the wires hooked together but dont this fuse keeps your dryer from burning up. You should also clean all the excess lint ect from the bottom of the dryer and as far inside the vent access as you can. The thermal fuse goes out when there is a build up of heat that is abnormal. You may be supprised at how much change you find in the bottom of the dryer I have found as much as 30 dollars in one. When you are in the dryer back also look at the hi heat limit it is mounted on the heating element casing if the wires are burnt ect.. put new ends on them and replace the hi limit it is held on by two screws and its best to replace it if the wires have burnt or melted any. I hope this helps you good luck
Posted on Aug 19, 2010
    Champion:
  • 245 Answers
It is either your element or one of your thermal cutoffs!
Dryer will not get hot
how old is it? One thing i run into a lot, is that the exhaust vent may be clogged.
if that is the case, clothes tend not to dry due to lack of air circulation. And the heating element in the dryer will not kick on. That vent is typically located in the back lower panel of the dryer. And is hooked up to a vent hose. check the hose for debris (lent) remove anything you might find. also disconnect where the hose meets the dryer, and check dryer portion as well. If nothing is clogged, then you may have a bad heating element.
Apr 05, 2014 | Whirlpool Dryers
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
Low heat
Dryers either heat or they don't heat. Complaints of "low heat" are always due to a restriction in the venting system.
There is either a clog in the hose somewhere or the hose is smashed. There could be an obstruction at the exit outside or the hose runs longer than 12 feet before exiting the house, to name a few.
Mar 09, 2014 | Magic Chef Dryers
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
My Amana electric dryer, Model # NED4500VQ0 is not heating clothes enough to dry a load in one cycle. I changed the thermostat already. The back glows orange and is heating. I figure it has to be the...
Not sure about the hh limit or the element, but make absolute certain that there is good flow of air. Check to see if the vent is clogged. Remove the hose from the back of the dryer and see if air is flowing very hard. Use a vacuum cleaner or a wire or something if it is clogged. Similarly, check the hose itself. If the hose collapses when you attach a vacuum to it, it is clogged. Dryers require heat AND air flow to dry properly. :)
Mar 22, 2012 | Amana Dryers
Dryer wont heat up
check the vent hose. It may be clogged with lint. best spot is to disconect the hose from the dryer that is usually where the clog is. Also check for spots the hose is pinched.
Note it is not the gas line or anything to do with electrical. it is a flexible hose that usually blows hot air outside.
Jan 03, 2011 | GE DRSR483ED Electric Dryer
My dryer takes almost 2 hours to dry a normal load of clothes.
You have a clogged vent , or kinked vent hose , or the hose to the outside ( possibly in the wall ) , is clogged with lint . A dryer , either heats , or doesn't heat . The venting , is what causes the excess timing , for the clothes to dry .
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
My 80 Serie Kennmore dryer will not dry my
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
Good Luck!!
Thanks
Jul 08, 2009 | Kenmore Dryers
Gas dryer heat cycles on and off about every 45sec's removed vent hose and problem still occures?
Check your heating element and also the high pressure switch which is located on the metal part behind the panel on the back of the unit where the vent hose connects sounds like your unit is over heating
Apr 17, 2009 | KitchenAid KAWS850L Dryer
Kenmore 62802 Electric Dryer Logo
275 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
