Question about True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
  • True Master
  • 1,144 Answers
In many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Posted on Aug 21, 2010
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Proper defrost time true t-49f
They don't even ship them properly set. They expect that a trained technician is on site at start up. I generally use 4 defrosts in 24 hours at 30 - 45 minutes each. It depends on which timer is installed.
Mar 28, 2012 | True 49 cu. ft. / 1388 liter Commercial...
The freezer keeps defrosting and not keeping food frozen
I would check your defrost timer to see if it is rotating. It may be stuck in defrost mode. you can check this by manually rotating the timer dial CCW yourself. This will be located in the front bottom left had corner behind the vent panel.
Jul 17, 2011 | True 49 cu. ft. / 1388 liter Commercial...
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Product in my true gdm-49f freezer is frosting up and there is an ice build up around the inside of the case. what could be the causes of this.
Try defrosting the unit by shutting it down until all ice is gone. If this corrects the problem and the ice returns you may either have a defrosting problem or a low freon charge.
Jan 20, 2011 | True 49 cu. ft. / 1388 liter Commercial...
I have a T-49 freezer with compressor running defrost timer board is showing in refrigeration mode. I have power on the #4 terminal going to the evaporator fans. Both door switches are closed. I am not...
most freezers have 2 controls. 1 is a defrost terminator and the other is a fan delay. the delay and the defrost terminator can sometimes be a "2 in 1" type switch. you would have to study the wiring diagram. The delay will not let the fans come on untill the evap reaches a preset temperature. take another look at the diagram. It may be that the evap is not getting cold enough. you may have a refrigeration issue.
May 15, 2017 | True 49 cu. ft. / 1388 liter Commercial...
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Dec 13, 2007 | True 49 cu. ft. / 1388 liter Commercial...
True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC Logo
263 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
