Question about Mr Steam SUPER SERIES STEAMBATH GENERATOR MSSuper3EC1 Stainless Steel
When i turn on my mr steam it does nothing. doesnt even take in water. the solenoid is fine there just isnt 24v going to the solenoid. Whats the problem?
    Problem Solver:
  • 11 Answers
Hi my name is Mike I am with Mr. Steam Product Support please give me a call with the model # and SN of your unit. you can call me at 800-767-8326 or email at mnail@mrsteam.com
Posted on Aug 20, 2010
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
The temp gauge reads correctly for a while then it starts going from cool to hot faster the water can change temp. I have changed the sensor
try the thermostat, located on the top radiator hose. top side of engine. also does it steam?? does it lose water but no leak, does the heat blow hot? if your heat isnt hot and it steams and loses water you may have a cracked head or head gasket. if you have heat, doesnt lose water and doesnt steam it may also be your water pump. most pumps will leak visibly from the weep hole when running
Aug 02, 2011 | 1999 Dodge Caravan
My mr steam is not steaming. We turned it on and 20 minutes later nothing happened. WE tried jump starting it with pouring cold water and that helped but it didn't reallly build up much of a stem before...
Hi my name is Mike with Mr. Steam Tech Support please call 800-767-8326 and ask for Tech Support and I will be more than happy to help you with you problem. please note I will need your model and SN Thanks
my ext is 1280
Dan ext is 1288
Mel ext is 1275
Sep 27, 2010 | Mr Steam Mr. Steam Steambaths Bulter...
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
Steam vapors dissapate before unit cancome back on
could be a bad sensor or relay. is it happening when it 1st comes on, if so this could be very true and when it does go into the shutdown part of steam generation it stays off for an extended period as well. try it out for yourself and see what happens as it cycles. could be that throwing water on the sensor caused it to give faulty readings or anything else. probly not design for that kind of shock.
Jun 13, 2017 | Mr Steam Mr. Steam Commercial Steambath...
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
When I turn on my steam unit it powers up takes
go to the following link
http://www.manatron.net/Pdf's/Sussman/residential.pdf
the manual may help you with yur problem.
it is hard to say what is wrong without looking the actual unit.
Apr 06, 2009 | Mr Steam Mr. Steam Allegro Sauna Model...
Aprilaire 560 constantly drains water
check to see if you have 24 volts between to 2 yellow wires coming out of the water solenoid. if you have 24v, then it is still getting energized to run. if it does not have 24v and the water is still running, the solenoid is stuck open. most likely from water deposits. sometimes you can take the solenoid apart and clean it, but probably better off just getting a new solenoid.
Feb 07, 2009 | Aprilaire Humidifiers
Mr Steam SUPER SERIES STEAMBATH GENERATOR  MSSuper3EC1  Stainless Steel Logo
271 people viewed this question
Top Mr Steam Electrical Supplies Experts
BJ Russell
Hippy_dd
Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
