Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LE on display panel. I have taken front panel off and all wiring has already been electrically taped together, so I don't think it is wiring. (This was done by a service rep when I had 1E problem) How do I tell if the impeller, rotor or blade is blocked? Or sump assembly or main power control board needs to be replaced?
  • 1 more comment
  • kimawatson Aug 20, 2010
    When you say take the back cover off, I am assuming you mean pull the dishwasher out of the space....the motor is in the way back and not the back of the front panel....
    You said to take the back cover off....I pulled my dishwasher out and I can't see a back cover on the back of my dishwasher...it appears to be completely connected to the 2 sides...like it is one piece. Is the back cover somewhere other than the "back" of the machine?
    Bear with me!
  • kimawatson Aug 23, 2010
    In order to get the M120 off, do you have to unscrew the screw on the M130 or does the M120 pop off with force without taking the M130 off?
  • LG Master
  • 12,061 Answers
Http://www.justanswer.com/questions/2bijk-i-have-a-lg-ldf6810st-dishwasher-with-an-error-that-the-service
Hi please go to this website below, it directly addresses your issue, there are pictures etc, for you to look at.
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Link below is for your service and repair manual.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=51
Posted on Aug 20, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.Error LE indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 19, 2010
Duet dryer wont start beeps and sensing lights up!
Its likely your thermal fuse is out.
Disconnect the power! Remove the lint filter screen. Remove the two screws from the bottom flange of the toe panel. Pull the toe panel out at the bottom, pull down, and remove the panel. Remove the screw from the lint duct bracket and remove the bracket. Remove the two screws from the lint duct and remove the duct.
Then you will see the white thermal fuse on your blower wheel housing. You can jump it with an alligator clip or take the wires off the thermal fuse and use electrical tape to tape them together to see if it comes on. DON'T LEAVE IT JUMPED TO RUN A CYCLE, order a new one.
Here is a the part.
Oct 20, 2012 | Whirlpool GEW9250 Electric Dryer
Tip
Easy fix for the turn off on the HZ-709 oilded radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
on Mar 25, 2008 | Honeywell HZ-709 Oil Filled Radiator...
All the speakers including the sub do no have any sound coming off. The only speakers that have sound coming from them are the very last ones in the back seat. How can I fix this?
Check the wiring of the speaker that don't work, it might have been disconnected or the wires are cut.
Look at the wires inside the door panel, which the front speaker is located, the wires leading to it might have disconnected via door panel wire harness inlet. You could see the wires at or near the front door pillar hinges.
If the wire is cut off, strip the wire and join them together, wire color should be connected with the same color. After that insulate them by using electrical/plastic tape.
Your local technician can repair it.
Hope that helps you out.
Thanks for using Fixya!
Jul 10, 2011 | 2006 Nissan Sentra
I have power to 3/w switch, and 3wire cable that goes thru 4 lights to a 3/w switch. Can I wire all 4 lights to come on and off with the two 3/w switches ? If so how?
Yes, you can. Since you have power at the one 3-way switch already. Use two of the three wires to go DIRECTLY through to the other 3-way switch. Make sure NOT to connect these wires to anything other than to the 3-way switch. Now, you have power at the one 3-way switch - and the two wires (called travelers, jockeys, etc.) going directly over to the other 3-way switch. You already have your neutral at your lights, so that's taken care of. Now, wire each of the four lights together - and take your remaining wire down (connect it) to the (powerless) 3-way switch where you just brought the two travelers/jockey wires to. Land this on the colored/odd screw on the 3-way switch. Now, the 3-wire cable that came from the 3-way switch that had power to it already...has a remaining wire that you will cap. You used the two wires to go directly over to the other 3-way switch - and now, that third wire can just be capped (or taped off). So basically, you have power at one 3-way switch. You have two wires going directly to the other 3-way switch. And from this switch, you have a wire going to your lights. The neutrals are connected together between the four lights (which I'm presuming have already been connected back to a neutral source, or your electrical panel). I hope this helps. If not, please contact me again. Good Luck, and I wish you well.  - Jim
Apr 14, 2010 | Hammering
My dishwasher is showing LE on the display and will run but doesn't seem to be cleaning the dishes. Any solutions?
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
Mar 27, 2010 | LG 24" Built-In Dishwasher - Black
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
Door open sighn comes on display drum does not
take out door switch and tape the two wires together, if the washer works fine this way, then the door switch is bad. if the door switch fails it cuts electricity off to motor.
Jan 14, 2010 | Whirlpool AWM6141/1 Front Load Washer
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
Thanks
Jun 27, 2008 | Dishwashers
Le Creuset Kone Electric Kettle (apparently)
no because it isnt realy safe to do that because the tape can melt
Nov 27, 2007 | Le Creuset Kone Electric Kettle
or
Nov 07, 2007 | Honeywell HZ-709 Oil Filled Radiator...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
67 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
