I cannot get a pictrure on my LC195B24U sharp computer monitor
Background too bright
What about the TV reception? Is it alright?
Apr 29, 2012 | Televison & Video
How can I open the case of a Sharp LL 172A-B 17"
Gently pull the frame off because they have lock latches.
Nov 11, 2010 | Sharp LL 172A-B 17" LCD Monitor
I need to find drivers for a Sharp LL T17A4-B 17 in. Flat Panel LCD Monitor. I recently changed it to a different tower and cannot find the driver for it.
Hi
Thanks for using FixYa. You can download its drivers by clicking on any of these two links:
Sharp LL T17A4-B Drivers
Sharp LL T17A4-B Drivers-2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 08, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
Does it have speakers and haw to turn them on
as shown form the pictrure from hp it seems it has. check if you conected the jack in your computer and monitor. start the menu of the monitor using the buttons on it and try to get something like sound. if this doesn't help test each button of the monitor to see. they may have separate functions than the ones from the menu
Jan 25, 2010 | HP W19b LCD Monitor
About text sharpness
The monitor shouldn't be changing the settings itself unless you changed it. Try changing the brightness and contrast. Otherwise, it might be a video card issue.
Nov 30, 2009 | Samsung SyncMaster 551 15" CRT Monitor
Screen returned from supplier background bright pink, how do I change to white background.
To check if the video card or the Sharp LCD monitor is faulty, connect a different monitor to the computer. If this monitor displays a normal image then the video card is OK and the Sharp LCD monitor's back-light is faulty. Send it back to the supplier to have it fixed (they should not have reurned it to you in this condition).
If the other monitor also displays a bright pink background then the video card is faulty and needs to be replaced.
Nov 19, 2009 | Sharp Computers & Internet
I need the drivers of sharp xr-11xc projector
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
It looks to me that this projector hooks up to a computer like a monitor. Page 60 refers to compatible computers and page 23 for device connections. Hope this helps.
Jul 09, 2009 | Sharp Computers & Internet
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
Horiz. sharp line from 2 inch bottom
If the screen is part of your laptop/notebook/netbook, try to connect an external monitor to the VGA port, to see if the video-card in your computer is generating the "weirdness".
If the screen is an external monitor, try connecting it to a different computer, to see if the "weirdness" follows to the new computer,
implying that the monitor is faulty. Also, connect a diffferent monitor to your computer, to see if the video-card is causing the problem.
Sep 22, 2007 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
