Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
How do i change out a projector lamp in a kodak cavalcade projector?
    Genius:
  • 1,175 Answers
Do you have the manual?
I would try a camera store for real help
Posted on Aug 19, 2010
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
I have a 750H Kodak slide projector. Where do I find a bulb for it?
The KODAK Carousel 750H uses a 300 watt, 120volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 19, 2010 | Kodak Office Equipment & Supplies
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
Kodak slide projector Kodak 600 burning bulbs, fan is working
Excessively short lamp life is usually caused by material building up on the lamp socket terminals, caused by arcing. This material build-up causes higher current loads and will ultimately shorten lamp life. A new lamp socket is a simple solution to your problem!
Feb 16, 2010 | Kodak Office Equipment & Supplies
How do I open my Kodak Instamatic M70 projector?
I have a Kodak Instamatic M70 Super 8 movie projector. How can I stop the film from continously jumping? I have adjusted every nob and looked inside to find nothing out of the ordinary.
May 16, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Koday Ektagraphic III projection lamp differences
The newest style eliminated the heat absorbing lens and (I think) made the mirror do that job. This improved the light output marginally. I don't know if the new style of lamp module is still available or not. You can ask a Kodak dealer or if in the US/Canada (shipping applies) try www.micro-tolls.com and search for p/n 2H2256.
Alternatively you can use EXW lamps which are high brightness (though still 300 watts). However these are very expensive and have a short lamp life...15 hours I think.
Jan 01, 2008 | Kodak ATS Ektagraphic Slide Projector
New lamp
http://slideprojector.kodak.com/plugins/acrobat/faqs_lamps.pdf
This link tells you the lamp type you can use. EXY, EXR or FHS. http://www.bulb-source.com has the FHS for around $10.00. Seems like a good price for the lamp. Other suppliers range from $8 to $25.
Dec 31, 2007 | Kodak 4200 Slide Projector
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
61 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
