SOURCE: logitech quickcam communicate stx
Check the camera settings are not too high 320x480 or similair should be enough. Have you installed Windows Messenger live, the new MSN and tried it with that? If your'e problem persists try this problem page. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=534&p_created=1087233145&p_sid=tDSxcPki&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQyMiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aWxsIG5vdCBpbnN0YWxs&p_li=&p_topview=1
SOURCE: Logitech QuickCam STX vista compatibility?
when you were installing the software did a taskbar pop up appear and tell you that hardware was found, and then proceeded to install the cam and inform you that the Logitech STX is now installed and ready for use? If not then the cam may need to be tried in another usb port as of yet it has not been recognised by windows. Also if this is being used on a laptop, sometimes there is not enough power amps being sent be the usb port to recognise, again trying a different port may solve that. If all else fails re install the software again, but make sure windows is allowing the cam to work, as sometimes there is an updater programme that works in conjunction with the cam to update drivers etc, this will probably be being dissalowed by either windows or your internet security programme and any part of the software that is being blocked may be stopping your cam also.
Have you updated DirectX?, I'm not sure if Vista has DX9.0 or 9.0c, but you could try and update DirectX before you install the cam software. Also if the cam is usb, did you install the software "before" connecting the cam?, some people aren't aware that usb devices have to have the software installed first, before connecting the device.
SOURCE: logitech webcam download
http://www.logitech.com/index.cfm/435/352&cl=us,en?WT.ac=sc|downloads||dd
Click there. Choose your OS. Then choose 32 or 64 bit.
Download and install.
To find out what OS and 32 or 64 bit, right click My Computer, select Properties. The pop up from that has all this information. XP or Vista. 32 or 64. (If you have XP, it won't show 32. If you have 64, it will. So, if you don't see either, you have 32 bit.)
Let me know if you have any questions.
SOURCE: Can't get hold of driver for logitech webcam v-uas14
http://www.logitech.com/index.cfm/435/3480&cl=gb,en?WT.ac=sc%7Cdownloads%7C%7Cdd
Since you posted your problem under Sphere-cam i asume that thats the cam u have. So try this link above and you will find the drivers you need.
Good luck to you
Please take a moment and vote
Nic
