Question about Garden
Coleman 10hp generator model 19E412 type 0107 01 code 9701141A
  • 8 Answers
SOURCE: coleman generator model PMC525501
pramac bought coleman power mate phone 1-800-445-1805
Posted on Oct 15, 2008
CarlGehrke
  • 169 Answers
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Posted on Dec 15, 2008
  • 143 Answers
SOURCE: Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Posted on Aug 13, 2009
cj2176
  • 520 Answers
SOURCE: coleman generator not putting out enough volts
What can happen with these generators is there is a shield built into them to devert the heat that is produced but it is still released into the surrounding components and causes a plastic rain guard to melt slightly around the edges and the melted plastic fuses to the armature and causes voltage drop through the brushes due to lack of contact. It is a relatively simple fix but it requires a rebuild kit that can be purchased aftermarket through your local generator dealer. It provides instructions for the rebuild but are often times confusing and it is usually cheaper in the long run and less hassel to let the dealer install the rebuild kit for you. If you do decide to attempt this yourself there is an 800 number provided where it can be registered and it will allow you to access schematics online for this rebuild. Hope this helps, good luck!
Posted on Sep 02, 2009
  • 468 Answers
SOURCE: i need the setting for my coleman power generator 10hp tecumseh
If you have fire coming out of the carb, then your intake valve is stuck open. Take the head off, and as you turn the engine, tap on the valve with a plastic screwdriver handle to make it go in, then turn it more to push it back out. If you need to put a light coating of oil on it, so be it. Keep doing this until it's freed up, then put it back together.
Posted on Feb 01, 2010
Looking for a carb for a Coleman Powermate 500/6250 generator with a 10hp Briggs and Sratton engine...any suggestions?
As it is a Briggs Engine most quality Briggs dealers can get the carb. It isn't special to Coleman I don't believe.
Oct 08, 2013 | Coleman Powermate Premium Plus 6250W...
Briggs and stratton 10 hp model 19e412 broken on/off switch
do you have a diagram of the switch wire connection fro model # 19E412
Sep 26, 2012 | Briggs & Stratton Power Products 5,550...
Coleman carburador 10hp
where i can get a Coleman carburator powermate 5000w
Sep 10, 2011 | Coleman Powermate Portable Generator...
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Sep 27, 2009 | Coleman Electrical Supplies
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
