Question about Ovens
Hello, I have a scd302tp and the convection element just went up in a puff of smoke (literally). It looks like it shorted out and melted. I ordered a new element and replaced it but it still doesn't work. I re-set the over-temp button but that did nothing either. Everything on my electronic display seems to be functioning properly. Do you have any ideas I could try? Regards, Gary
  • Ovens Master
  • 11,800 Answers
When it shorted it fried the relay that is powering it - replace that. Also check the command to the relay, it might also been fried.
Posted on Aug 19, 2010
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Lower Oven Element
Are there fuses in this stove. There usually are in most electric stoves Quite often in the back behind the clock if there is one..
You may have blown a fuse.
Oct 18, 2017 | Frigidaire GLEB30S9F Electric Single Oven
I'M LOOKING PART OF THIS MODEL Thermador SCD302TP
Hello, welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal for your SCD302 series Thermador double wall oven. They should have anything you need.
http://www.repairclinic.com/Model-SCD302TP-ID-642642-Parts
Thank you for choosing FixYa and good luck. Please take a moment before leaving to rate the assistance provided here and your experience at FixYa.
Regards,
Macmarkus :)
Sep 19, 2011 | Thermador SC302T Electric Double Oven
Turned on my electric oven and it made a bang and a puff of smoke appeared what is this?
something shorted out,, unplug it, and remove the back cover, Look for any burned spots that will look like little white marks,, usually when that happens its the element, But if it fed back to the control switch that can burn also
Jul 15, 2011 | Belling XOU482 Electric Double Oven
Will not heat up past 200 bottom element is brand new?
Hello- It sounds like it is not getting 220V. I would first check the breaker and reset it a couple of times to make sure that it is sending 220V to the oven. There could be a problem with the relay board not sending enough voltage to the element. I would also check to see if the convection element is ok, it may share a common 120V wire with the bake element. If you are unsure about testing the elements then I would call a Tech out to test the voltage. The oven may have to be pulled to determine if there are any shorted wires. Good luck and best regards.
Sep 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
The bake element burned out in my electric oven
element may have shorted . ck the element first and if bad replace it then reset the house fuse and retry. mm
Jul 14, 2010 | Whirlpool RBD305PD Electric Double Oven
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
