Philip 50" DLP blue light in front flashes 6 times slow followed by 5 times fast. The bulb light came on I have just replaced the bulb now I get this problem. Anyone know what is going on?
  • 1 more comment
  • pastortravis Aug 19, 2010
    I took the lamp cover off and put it back on making sure that everything was in position correctly.. I am still getting the same problem.. The TV acts like it is coming on and then you hear a click and the light then starts blinking 6 times slow 5 times fast. The TV model number is 50PL9126D/37
    Thanks.
    I took the lamp cover off and put it back on making sure that everything was in position correctly.. I am still getting the same problem.. The TV acts like it is coming on and then you hear a click and the light then starts blinking 6 times slow 5 times fast. The TV model number is 50PL9126D/37 Thanks.
  • pastortravis Aug 20, 2010
    50PL9126D/37B is the model number for my TV.. The lamp went out in the TV and I replaced it. Now when I turn it on the fans and everything come on, but I get no picture and then I can hear the TV click off and then the front light begins to flash 6 times fast and then 5 times slow. I was told I need to call Philips, but it has no warranty.. I am sure what to do??
  • 10,594 Answers
Make sure lamp cover (its the first thing that you removed from tv cabinet to replace lamp) is fixed on its position correctly.
Lamp cover push a micro safety switch that tells system control that lamp cover is tight.
If lamp cover has not been fixed back in position, tv wont turn On.
Let me know model number of tv if you have additional question.
Thanks.
Posted on Aug 19, 2010
  • 18 more comments
  • Shahid Electronics
    Shahid Electronics Aug 19, 2010
    Thanks for model number 50PL9126D/37
    get back to you shortly.
    Problem sounds with ballast supply board that drives lamp with high voltage.
    If you follow red thick wires from lamp housing, it will take you to ballast supply board.
    This is not user level repair and visual check by qualified tech is necessary, please call Philips service center to send out tech.
    Shahid Electronics Aug 20, 2010
    I replied you after reading related service manual.
    Do you have any idea what the cost would be to fix the problem??
    ah, again I have to break unpleasant news
    If Philips provides you ballast supply separately then cost would be around $350 or so
    Well thanks for you help.. Sound like I am just going to buy a new TV.. I don't want to put anymore money in this TV.. From what I read this TV has a lot of issue.. Thanks for your help...
    do you know the part number by chance??
    Its OK, I'm sorry I was not so helpful to resolve your tv issue that is bit complicated hardware problem.
    Can you please change rating of answer?
    I see it is 2 stars that counts very low.
    Thanks.
    Part number is written on ballast supply board, once you take it out.
    I'm still thinking about lamp and its installation, is it Philips original lamp supplied with its black housing?
    Are you sure that new lamp has been installed correctly in two thick wire connector in its box?
    The lamp came without the black housing.. I ordered it from a TV supply store online.. I just took the old one out and connected the wires back.. everything seems to be good and tight.. Is there a way to check in see if the lamp is getting power??
    how do i do that??
    how do i do that??
    how do i do that??
    how do i do that??
    how do i do that??
    how do i do that??
    how do i do that??
    Did mean to reply so many times.. my computer messed up..
    The lamp was purchased from a TV supply store online. It did't come with the black housing.. is there a way to test to see that power is getting to the lamp?? Thanks..
    humm, that means bulb was replaced in old lamp housing, right?
    recheck lamp connections and two lamp wires that should tight
    Lamp can be tested in another tv that use similar lamp, do not try to measure ballast volts as these are high volts approx 15K or more
    frankly, I do not trust these low price bulbs and always recommend to buy original lamp from manufacturer (Philips)
    Rating can be changed by accepting solution/ assistance
  • 3,866 Answers
1. did you close the hatch?
If you just replaced the bulb you need to button up the tv basically put it back the way it was not leaving the access door open.
if the hatch door is closed you might want to go back in there and check the bulb. if the bulb is good it might be a ballast issue.
let me know
otherwise please do click the accept button for my efforts.
Posted on Aug 20, 2010
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
I have a Hoover Zodiac12 2-speed reversible motor i want to use for a home project. Its a Nuova Ibmei with 5 terminals. The wires are L to R and top to bottom; 1. black stripe, 2. blue, 3. yellow, 4. red...
You will destroy the motor by running it with multiple speeds tied together. So be careful. Just try and get it to work with 2 wires and tape the others off away from each other and the frame so they won't short anything out. themobilian_795.jpg
Jan 04, 2011 | Washing Machines
My Philips tv 60PL9200-37 has sound,but NO picture. The front blue light flashes 6 times slow,pause,5 times fast. Once in a blue moon picture and sound are ok. What could be wrong?
When your television actually flashes the front blue light, it is passing a message that there is a problem inside the unit. There are 2 things you should check but my best bet is that it is the t-con board of the television that is bad. The other component you can check is the lamp, but if the lamp is faulty you will not be getting sound therefore the problem is from the t-con board.
It is located by the middle of the main panel of the television, once you get it replaced, the television will be in good shape.
Take care and good luck
Jan 02, 2011 | Philips 60PL9200D Projection Televisions
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
Red light flashing.set will not start up.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
I have to unplug wait for the power light to stop flashing red multiple times before it will come on
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Right turn signal
have the same problem, sounds like you will need to get a new light socket (where the light bulb goes into).... it is a easy fix. cost approx $30-$50 at dealership for part
Oct 04, 2008 | 1998 Buick Century
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
