Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
How do you get a factoring program onto this calculator, that could factor 3 terms? Like X^2 2X - 3 = (X - 1) (X 3)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
There are several factoring programs available at
http://www.ticalc.org/pub/83plus/basic/math/algebra/
Posted on Aug 19, 2010
-54k^2+3k
-54k^2+3k I assume that you want to factor this completely.
I do it one component at a time.
What is the biggest common factor of -54 and 3. I use a trick of adding the digits of the number. If 3 and/or 9 go into that number evenly, than 3 and/or 9, respectively go into the original number. In this case, 5+4 = 9 and since 3 goes into 9 evenly, 3 goes into 54 evenly. Since the factors of 3 are 3 and 1, this must be the greatest common factor of this component.
Onto the next component, what is the greatest common factor of k^2 and k. The answer is k, because k^2 doesn't go evenly into k.
Combining the two, the greatest common factor is 3k.
Next we have to divide 3k into each term.
3k(-18k+1) or -3k(18k-1)
Good luck,
Paul
Mar 29, 2017 | Homework
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
Jul 05, 2015 | Casio FX-9750GII Graphing Calculator
What is the lowest terms for 711/22
To convert a fraction to lowest terms, we must divide the numerator (the top number) and the denominator (the bottom number) by a common number until we can't reduce it any more. A method for doing this is to factor the numerator and denominator by their common factors.
So let's factor 711 and 22.
1 x 711
9 x 79
3 x 3 x 79
I don't think I can factor 79. We should check the numbers from 2 up to the square root of 79, or approximately 9.
Factoring 22,
1 x 22
2 x 11
Unfortunately, none of the factors of 711 are common with the factors of 22, so it is already in its lowest terms, and cannot be reduced.
Good luck,
Paul
Apr 09, 2015 | Office Equipment & Supplies
Factoring program
What is the question. Your calculator FX-9750 GII does not have a Computer Algebra System or CAS, so you cannot factor a polynomial.
If you want you can try to find the zeros of the polynomial function (the values of x when the function crosses the horizontal axis) either by solving P(x)=0 or by graphing y=P(x).
Once you have the approximate roots x_1, x_2, ...,x_n, you can factor out the coefficient of the leading term (the term with the highest power) and write P(x) =a_n *G(x). here a_n is the coefficient of the leading term.
G(x) can then be written as G(x)=(x-x_1)(x-x_2)*(x=x_3)...(x-x_n)
and the original polynomial will be
P(x)=a_n(x-x_1)(x-x_2)*...*(x-x_n)
Note: Here is an example of P(x) and the corresponding G(x)
P(x)=5x^3+7x^2-13x^+29
P(x)=5(x^3+ (7/3)*x^2-(13/5)x+29/5)
G(x)=x^3+ (7/3)*x^2-(13/5)x+29/5
You should keep in mind that the roots are in general complex. Not all polynomials are factorisable in the set of Real numbers.
Oct 06, 2013 | Casio FX9750GII Graphic Calculator
Simplify the expression 0.2y3+0.3y3+0.1y3 use integers or decimals for any numbers in the expression.
All the terms in the expression have a common variable factor (y^3). factor it out to get (0.2+0.3+0.1)y^3=0.6y^3 or (6/10)y^3 or (3/5)y^3.
Apr 19, 2013 | Office Equipment & Supplies
How do i factor
This calculator is unable to factor a polynomial expression.
In general there are a few factoring methods
  1. Factor by grouping terms
  2. Factor by completing the square (quadratic polynomial)
  3. Factor by finding two integers such their sum is equal to the coefficient of the middle term, and their product is equal to the third (constant term). This is valid for a quadratic polynomial where the leading coefficient (of the x^2 term) is equal to 1. X^2+SX+P
A cubic equation can be solved algebraically, although two solutions may be complex. Use the Cardano formulas. A quartic equation can be solved by the formulas for the quadratic equation, if you transform the quartic equation to look like A(X^2)^2 + B(X^2) +C=0
Jul 31, 2012 | Casio FX-115ES Scientific Calculator
How to you factor trinomials
The short story is that this calculator does have a computer algebra system or CAS and thus cannot factor polynomials with arbitrary (unknown) coefficients or known coefficients.
However if the coefficients are given you can ,if you are willing to travel that way, factor approximately a polynomial P(x).
Basically, the idea is that any polynomial P(X) of degree n can be written in the factored form (X-x_1)(X-x_2)...(X-x_n), where x_1, x_2, x_3,...x_n are the roots (real or complex) of the equation P(X)=0.
The procedure ( for a 3rd degree polynomial) is as follows:
If you want to factor a cubic polynomial P3(X) = aX^3 bX^2 cX d , you write the corresponding cubic equation as aX^3 bX^2 cX d =0 , then you divide all terms of the equation by a to obtain
X^3 (b/a)X^2 (c/a)X (d/a)=0.
You use the calculator to solve (approximately) this equation.
Suppose you find the 3 roots X1,X2,and X3. Then the polynomial X^3 (b/a)X^2 (c/a)X (d/a) can be cast in the factored form (X-X1)(X-X2)(X-X3) and the original polynomial P3(X) can be written as
P3(X) = a*(X-X1)(X-X2)(X-X3)
You can handle the quadratic polynomial the same way.
P2(X) =a*(X-X1)(X-X2) where X1, X2 are the two real roots.
Sep 11, 2010 | Casio FX-9750GPlus Calculator
How to factor a polynomial equation on casio fx-300es?
The Casio FX-300ES does not handle symbolic algebra. So it cannot factor a general polynomial expression. The methods can be found in any book on Algebra.
However if you are interested in approximate factorization of quadratic and cubic polynomials, you can use the calculator to do that. It can solve aX^3 +bX^2+cX+d =0 and the quadratic equations.
If you want to factor a cubic polynomial P3(X) = aX^3+bX^2+cX+d , you write the corresponding cubic equation as aX^3+bX^2+cX=d =0 , then you divide all terms of the equation by a to obtain
X^3+(b/a)X^2+(c/a)X+(d/a)=0.
Suppose you find the 3 roots X1,X2,and X3. Then the polynomial X^3+(b/a)X^2+(c/a)X+(d/a) can be cast in the factored form (X-X1)(X-X2)(X-X3) and the original polynomial P3(X) can be written as
Hope it helps.
Sep 27, 2009 | Casio fx-300ES Calculator
Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Apr 17, 2009 | Casio FX-115ES Scientific Calculator
When factoring or finding deriv. it gives me number?
oh yeah, you must've archived x, that is, you put a number onto the x variable so that the calculator calculates the answer for you, and THEN AUTOMATICALLY calculates the answer when x is in terms of that number. I am guessing you accidentally did 10[sto] x at one point. You can simply unarchived the x number and everything will be dandy!
Dec 08, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
362 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
