Question about Garden
I have a Ryobi power washer with subaru motor, model #RY30080. I bought it 3.5 years ago. I only used it one time as purchased. This summer,it did not start. Yes, I left gasoline in the unit. I did not know that it require to drainout the gas prior to winter storage. Help, what can I do to get this machine starting again. Used only one time.
5 Suggested Answers
  • 174 Answers
SOURCE: Pressure washer sputters and stalls when trigger is engaged
Hi k2times01
It is a always a good idea to clean out the gas tank and use new fuel, however, this sounds like an RPM problem. Try adjusting the RPM up a tad and see if it runs better when you load it. If the RPM isn't the problem, you may have to clean the carburetor thoroughly.
Posted on Jul 15, 2009
jmgldsmth
  • 1869 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
SOURCE: Bought unit new last summer.
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Posted on Oct 13, 2010
ftw1952
  • 10319 Answers
SOURCE: will not continue to run after start. new gas tank
was the carb drained before stowaged? if not carburetor cleaner is needed to clean the jets and float bowl out from varnish build up
Posted on Jun 11, 2011
My pressure washer appears to have died.
does the motor have rust in it??the motor can be replaced
Jun 18, 2015 | Bosch AQUATAK GO Pressure Washer
Ryobi will not start
The saw you're asking about is battery powered, not gas. If this is the actual model you have, I don't know where you could even put the gas. Have you charged the battery?
Aug 05, 2014 | Ryobi Brand New... 18v Cordless...
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Subaru Tribeca: Front screen washer doesn't work
AutoZone has free repair manuals online. Should be able to find fuse locations.
May 10, 2013 | Subaru Tribeca Cars & Trucks
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Fumes inside 1998 subaru forester
I had a 2000 with leaking fuel lines. There are a few molded rubber lines. Check the condition of the rubber and the hose clamps. If they are wet, you have a leak. When replacing use the good clamps that you can tighten with a nut driver
Mar 11, 2017 | 1998 Subaru Forester
No power is there a fuse in the dryer. The power is ok. Could it be the plug? It is at my summer home it is a stackable purchased about 3 years ago. I don't have the model. It was purchased at Lowes
There is a fuse in the dryer, its called a high limit sensor. If the dryer gets too hot the high limit blows like a fuse and saves your house.
Make double sure you have proper power at the outlet before you tear into the machine.
Good Luck
Quentin
Oct 05, 2009 | Frigidaire FEX831CS Top Load Stacked...
Subaru legacy sunroof wont open but motor turns
Same problem mine will only work when it is warm out because of the gasket. When there is the slightest difference in colder temperatures I need to press on the top of the sun roof while hitting the button to have it slide. Using the gasket cleaner may be a good idea. I haven't tried that yet though so don't take my word
Jun 28, 2008 | 1999 Subaru Legacy
Garden Logo
149 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
