Question about Microwave Ovens
I need new freezer and fridge door seals for a Leibher KDVES 4632-24/001
Freezer has ice in it and the fridge isn't cooling
Hello Cass, being that you have a top mount, the vent in the freezer is what circulates air down to the Fresh Food section, making it cool. Here are a few simple troubleshooting tips that may help you resolve this issue:
First check clearances around your refrigerator. There must be adequate space around a refrigerator with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the refrigerator.
Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the refrigerator. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure refrigerator is level and keep food and containers from blocking the door closing.
Check the door seal. You do this by placing a dollar bill between the body of the refrigerator or freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket.
Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the refrigerator will not get cool.
I recommend to double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 18, 2013 | Electrolux Microwave Ovens
Ice has built up behind the wall of the fridge. I can see ice in the little holes on the back wall. I also have water accumulating under the crispers in the fridge. I called samsung they have no clue...
turn it of and under your fridge or on the inside water is ment to full into the tray either the tray is full or your temp control is buggered. try tilting your fridge back about so it leans back and see if that helps but a new seal is about $20 and all you do is pul the old one off and pop the new one in place
Jul 04, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
I have an Inglis fridge and when door is closed there is about a1/8 of a inch space between the seal at the top and fridge . Bottom seals properly
That can be caused by hardening of the bottom seal due to ice build up in the seal or the door hinges need adjusting by loosening the lower hinge and pulling it out slightly to compensate for the door seal.
Mar 05, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
We have just taken delivery of a Bush fridge freezer BAFF55161W Friday and have plugged it in overnight to cool to temperature. However, we are unable toopen the fridge or freezer doo. Is there some type...
I have the same problem. i think they spray some glue along the sealant to keep it close in addition to sellotapeing the door. It may even just be a vacuum I ran a piece of card board along the door sealant and it opens.
Jan 08, 2011 | Microwave Ovens
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
My freezer is working but the rest of the fridge is hot
Hi, it is possible for your freezer to work when you fridge is not working. Fridge-freezer appliances have independent controls which can malfunction separately. If your freezer is fine and your fridge seems down, there are several things that could be wrong but what i suspect is that... You should check the damper door located between the freezer and fridge compartments to make sure it opens and closes, sometimes they get an ice build up there and this causes them to stick shut, remove ice with hair dryer or remove and device and replace this will solve your trouble.
Best of all is to call in a local fridge technician around to get it fixed, it won't cost you much...
Take care
Feb 18, 2010 | Magic Chef Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
