The motor runs at spin time but does not turn the tub. The clutch mechanism seems to drag or the tub turns hard can't tell which. any simple test to determine problem? Hotpoint Model# VBXR1060T8WB Ser: LS935445H
    Champion:
  • 245 Answers
Your drum brake is probably bad.
Posted on Aug 19, 2010
I have a E 12 code on my brand new Smeg Front Loader Washing Machine. I had two mats and they have not spun dry. Can someone please tell me whats going on with my Washing machine
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
Feb 01, 2017 | Smeg Washing Machines
GLET1031CSO will not spin. There seems to be a problem with the latch that hooks up to the lid; it stays locked
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
Jun 19, 2015 | Washing Machines
My frigidaire twin tub washer FWLT1161FDUHWT spin tub stop working what could be the problem
hum what do u mean spin tub no such thing? do u mean the drum does not spin?
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
May 11, 2015 | Frigidaire Washing Machines
Why dose my siemens e46 38 keep stoping clothes are sill wet fan seemes to be working water pump seemes to be working all fliters have been cleand
Sep 09, 2014 | Dryers
Why wont my machine motor go into spin cycle.
No spin, try these:
Jul 17, 2014 | Whirlpool Washing Machines
What is E47 error display
Jun 02, 2014 | Frigidaire ATF6000ES Front Load Washer
Tub will not spin unless I manually turn it, then it will take hold and finish spinning. Someone told me it was the clutch. The washer is 8 years old. Is it worth fixing?
If you are able to hear the motor running "normally" while the tub is not spinning, then it likely is the clutch. Leaving it running like this (motor on but tub still) will eventually produce an acrid smell which will confirm the clutch.
If the motor just seems to hum and not spin, then the start capacitor is likely faulted.
Both are reasonably cheap as far as parts go, but clutch replacement can be a chore. Capacitor replacement is very easy. If you are mechanically apt, you can replace the clutch itself.
This washer is definitely worth trying to save (my opinion), but ultimately it is up to how much time you have, how much money you want to put into it vs the cost of a replacement.
Sep 10, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Neptune FAV6800AWW Just stops agitating or spinning
“”It seems there is a slight leak (I think because of the top seal worn out)at the bottom which caused the clutch to seize up and preventing the unit from spinning CCW.”” Yep I’m sure you may have a slight tub seal leak. Was the One-Way Roller Clutches upper bearing ring and Clutch Pulley mounted One-Way Roller Clutches bearing severely rusted up? Could you turn the wash tub CCW by hand with very little resistance before you started into the Clutch Maintenance?
“”I removed the clutch and was able to clean and lubricate it. I guess I had the bolt on too tight and the unit refused to turn.”” I believe you did not have the upper One-Way Roller Clutches bearing ring seated in the Outer Tub correctly when you reassembled. It is a tricky fitment/reassembly process. If the ticking sound if coming from the area of the clutch pulley that tells me it still not quite seated properly.
I recommend to lay the Washer completely on its back with a 4x4 placed just ahead of the drain hose exit, the fitment process is a bit tricky. You have to get that upper One-Way Roller Clutches bearing ring seat properly in the base of the tub. I believe the ticking sound is coming from the Clutch Pulley assembly is that correct. When you opened up the Clutch pulley was the clutch spring OK?
“”Now the unit refuses to agitate or spin.I have conducted all tests on the unit I could find. Motor test, spin test, drain test, quick cycle test, etc, but it returns no codes. On normal washes it will fill, start to agitate then quit. Also the counter stops counting down. (did this before the clutch clean-up). “” Ok so that was the original problem correct?
If so I agree with the fist forum member’s solution. The Control Board is expensive unless you buy like I do e-bay used with Membrane Console. I feel you have lost PWM signaling from the Control Board to the Motor Controller input. The Main Control Board is in the Console. Can’t rule out a Motor Controller for sure but I lean toward the Main Control Board also P/N 25001217 item 23 for all series. Before that I would try reseating JP4 on the Motor Control Board. The PWM input signal from the Control Board comes into the Motor Controller on that plug. This digital signal controls Motor Speed and direction via the Motor Controller. This may buy you nothing but no cost involved also check for corrosion on the plug and mating Motor Control Board connector. The Service manual will take you through removing the Motor Controller it’s a tight work area as the clutch. Remove the AC power cord to the washer before these checks.
AZ Control Board 25001217
JP 4 on the Motor Controller;
Good luck......Rich
Feb 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
