Question about Macmillan Holy Cow! 250,000 Graphics Full Version for PC
I have just moved from XP to Windows 7. Is there an update for Macmillan Holy Cow 259,000 Graphics.
I have an older version of Macmillan Publish It Deluxe which does not run on 64bit sys. any fixes?
I assume you have upgraded to Windows 7 or 8. You could try two things - firstly, make sure that the user installing the software has full admin rights. Second, there is an option to tell Windows to run the software in compatibility mode. That works with most software, but for very old ones, the option may well be to contact the publisher and see if they can help. Good luck.
Mar 23, 2014 | Macmillan Publish It Deluxe
I updated on Windows 7 and now the maximum resolution i can get is 1024 x 768 when on XP i could change it to 1280 x 1024.The monitor is a Fujitsu Siemens 22''
You have to look for the drivers of that graphic card for Windows 7. XP and Windows 7 use different kinds of drivers for the same graphic cards.
Oct 07, 2011 | Computers & Internet
My problem is the graphics and pci, i need a driver, i reformat today and now i noticed that the cd driver was lost, my mother board is ASUS P5SD2-VM. pls help me.tanx
You can see all the list of drivers found for this Motherboard by clicking here.
You would need to select the appropriate OS (Operating System) first before it can give you the list of drivers that you need to download. (Example: Windows XP, Windows Vista, Windows 7)
If you have Windows 7, please download the video driver for Windows Vista.
If you are having trouble with the Global(DLM) link choose instead the Global or China links.
Hope this helps!
Apr 07, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My ACEDV capture card did not work at windows7
this card is incompatible with windows 7. however you can download it's windows 7 driver.
if you couldn't find it install it's win xp driver.
Jan 09, 2011 | Canopus ACEDVio Graphic Card
What video card comes with this computer?
IntelĀ® 845GV Integrated Graphics
64MB max. Dynamically Shared Graphics Memory
Jan 02, 2011 | Sony VAIO PCV-RS310 PC Desktop
Not compatible with my current version of windows what do I need to do?
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 24, 2010 | Macmillan Holy Cow! 250,000 Graphics Full...
My computer is set on automatic updates and it is unable to find file PRO11.MSI to update pls advise
Hi there.
Its looking for Office 11 to update and you probably have not got the installer (.msi) file on the PC.
All you have to do is skip that particular update.
Good luck and thanks for using FixYa!!
Apr 09, 2009 | Macmillan Using Microsoft Windows XP...
Macmillan Holy Cow! 250,000 Graphics Full Version for PC Logo
Top Macmillan Computers & Internet Experts
David Payne
David Payne
Are you a Macmillan Computer and Internet Expert? Answer questions, earn points and help others
