Cant open or release battry latch[presario v 4000]
  • 667 Answers
There is another little switch like slide near the side of the laptop towards the end of the battery compartment. This a lock for the battery latch. Slide the switch to unlocked position and then try releasing the battery again. When you put the battery back or a new battery in , be sure to slide the switch to the locked position. This is just an extra feature to make sure you're battery won't fall out. If this solved your problem PLEASE rate this as fixed. If not do not rate yet just add a comment letting me know what happened and I'll be glad to assist you further. Thanks and have a nice day.
Posted on May 03, 2008
How do I get my rear hatch door open,when you can't open it from the outside?
You can get it open in two ways: By using your key fob and remotely opening latch or by pulling inside panel on rear hatch and manually pulling lever to get latch to release. Most times when you cant get rear hatch to open normally is because cable from outside release handle to latch broke. Have cable and release mechanism inspected and replace worn or broken parts as needed.
Feb 07, 2016 | 2003 Ford Expedition
Hood latch broken
Re;Cant open the hood with the latch inside....
Does the hood release handle have 'resistance' when you attempt to open the hood ??
Jan 10, 2014 | 2000 Ford Mustang
2012 liberty rear latch stuck
no answer but same problem. ever figure it out?
Feb 03, 2013 | Jeep Liberty Cars & Trucks
My hood release latch is disengaged and i cant open my hood i need to know how to open it with out the wire
you will have to try to get to the hood release at the latch from either under the car on the front side of the latch or try to get to the release mechanism from the front of the car through the grill area if its accessible,you will have to get inventive to release the latch.
Apr 14, 2011 | Chevrolet Beretta Cars & Trucks
Need to remove battery, dont know how compaq presario v 3000
Hello sexychispa. To remove the battery of your Compaq Presario v3000, start by turning the laptop over so that the bottom side is viewable. Look for a rounded slot in the bottom that has a sliding tab within. This is the battery release latch. Using your finger, slide the latch and hold to release the battery. With your free hand, assist the battery out of its compartment and allow the release latch to slide back into place.
For more information on the process, be sure to view this link to HP's guide to removing batteries from Compaq laptops.
Hope this helped!
Feb 27, 2011 | HP Computers & Internet
The hood will not open on my 2002 subaru legacy. can you help me?
try having someone hold the hood release open while you lift the hood. sometimes if you push down first then up it will release. If there is no way to get it open you might try to see the bolts through the grille to unbolt the hood latch through the
grille. If you cant get to it that way try to come from the bottom. Sometimes you can put a long screwdriver through the grille opening and reach the hood latch where the cable hooks and pry it the same way the cable would pull it. If you cant get it through the grille you will have to come from the bottom with a long screw driver to reach the hood latch at the radiator support and find the latch release action. you will have to remove some splash covers under the rediator support.
Dec 15, 2010 | 2002 Subaru Legacy
Forgotten the power on password of my compaq presario 4000
disconnect the power, open up the case . find the watch battery, pry it out, wait 15 minutes, put it back in
Oct 07, 2009 | Compaq Presario 4000 System Board...
Hood release cable is broken
Is there any part of the cable inside the cabin that you can pull with a pair of pliers? I suggest that you try that. You may need to disassemble it from the pull handle to make that work.
Dec 25, 2008 | 1998 Chrysler Concorde
Battery stuck in compaq presario latch wont release it
You'll need to disassemble the notebook, i.e remove keyboard and such.
Jan 13, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
