Question about Smeg SUK62CMX5 Dual Fuel (Electric and Gas) Kitchen Range
Trying to install a second hand smeg suk62cmx5 electric cooker following the wiring diagram on the back of cooker when i switch on the mains fuse blows any ideas how to get passed this hurdle?
5 Suggested Answers
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
SOURCE: Smeg Oven blowing
Phew! I'm very grateful for all that freetek but it certainly sounds like I may have a problem outside of my ability. I guess I will have to bite the bullet and get some expensive engineer to come in and sort it.
As a layman I just can't understand how it works fine for 5 years and without any alterations made simply stops! :-(
Thanks for all the advice, I will post back when and if I solve the problem, or wether in simply ends on the dump!!!
Posted on Oct 16, 2008
SOURCE: I have a Smeg A1-1 Cooker. The main oven door does
you have to replace the door hinge's an easy fix but you have to strip the doors apart so a good time to clean.
Posted on Oct 03, 2009
Fuse board switch off
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 01, 2014 | Smeg SE399X/5 Stainless Steel Electric...
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
Sep 20, 2013 | Smeg Ovens
Range
Request the wiring diagram directly from Smeg.
Oct 27, 2017 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Blows mains fuse
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
Smeg oven SUK62CMX5 dial transfers have come off
I used ovenlettering.co.uk for replacement decals for my oven. Easy
to apply.
Dec 02, 2011 | Smeg SUK62CMX5 Dual Fuel (Electric and...
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Could not find power cable for SUK62CMX5
contact your supplier or manufacturer as it has nothing to do with fixya site
Aug 02, 2017 | Smeg SUK62CMX5 Dual Fuel (Electric and...
Smeg oven ss336-5 not heating
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Cooker not heating up
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg SUK62CMX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
74 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
