Question about Cell Phones
Phone does not charge. It is not the battery tho ive tried several batteries
    Genius:
  • 1,478 Answers
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Posted on Aug 19, 2010
Testimonial: "This was very helpful. But also when it use to charge it wuld take along time to charge n the battery wouldnt last very long then it wuldnt charge."
My phone wont charge at allits not the cable ive tried several ive tried about everything
  • I am guessing that you have tried multiple wall power adapters. I am also assuming that you have tried several usb cables. If you have not tried a different wall power adapter and power cable go do this first.
  • If I were you I would remove the battery and hold the power button down for 30 seconds. Then replace the battery and back cover. Try charging the phone. If it works you are good to go.
  • If this does not work something major is wrong with your phone. It is most likely a loose charging port. A cell phone repair tech can fix this issue. I would see if your phone is under warranty first.
  • Make sure the cost of the repair is worth it if your phone is broken. Compare the cost of a repair to buying a new phone.
  • This could also be a bad battery, water damage, etc. A bad power port is the most likely cause of your problem.
May 25, 2015 | Samsung Galaxy Mega 6.3 Mobile Phone
Camera S5200 nikon said battery exhausted when i went to take pic so I plugged it in to charge. light blinking but even though it looks like it is charging I cant turn it on to close lens
give it some time to charge up maybe? Ive seen electronics, even tho plugged into a power source, wont power on until theres a bit more charge on the battery, Idk why, but thats my only suggestion
Nov 01, 2013 | Cameras
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
Jun 06, 2011 | Nokia 5230 Cell Phone
My phone wont turn on or charge even tho i charged it all night
It sounds like you need to replace your battery. But first, if you're using a home charger, try charging the phone with a car charger (or vice versa). If the problem is not with your charger, then replace your battery.
When you get your new battery:
1) Make sure you are using the proper charger for your phone (not one of the cheep $5 kind), and
2) charge your battery for at least 12 hours before you use it for the first time.
Click here to see a battery for your phone on eBay: http://cgi.ebay.com/NEW-OEM-LG-VERIZON-VX8560-CHOCOLATE-3-LGIP-330H-BATTERY-/250764708864?pt=PDA_Accessories&hash=item3a62bdcc00
Jan 28, 2011 | LG Chocolate 3 Cell Phone
Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Motorola Mobility Boost i415 Cellular...
My phone doesnt charge
Your phone doesn't charge? or does not hold a charge?
If the battery meter is not running when ur charger is plugged in, it could be a charging port problem or a battery problem. Go to a nearby shop to have someone try another battery & to determine if that is a battery or a phone problem. If it's the battery then buy a new one. if it's the phone, have a Samsung tech repair it for you
Dec 15, 2009 | Samsung S3500 Cell Phone
My samsung juke wont turn on. ive charged it several times and still nothing. ive sent it to electronic experts and nada. ive taken th battery in and out and nothing. Ive held the END button on the phone...
Does the Verizon logo flash when you plug it in? I had this same problem. Take the battery off. Plug the phone in. Observe the flashing logo. Put the battery back in. Observe "Charging..." screen. Power on. Unplug. Good to go.
Jun 05, 2009 | Verizon Communications Samsung Juke Cell...
Nokia 6280
hi there try to clean the flex cable sometimes it shorts, or replace them. ok
peace!
Mar 28, 2008 | Nokia 6280 Cellular Phone
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
