Question about Haier Heating & Cooling
Haier, Model # HWR 12XC5 Started making a noise, smelt electrical wire burning smell then it stopped running. opened electrical box on AC did not see any sign of smoke but fuse was blown, changed fuse turned it on, it started running saw a flash it blew fuse again. can you help! Brian
  • gabbeyf Aug 19, 2010
    checked for burn marks none visible. the flash i saw was in the fuse
    i checked for burn marks around compressor and capacitor area and none were visible. the flash i saw was in the fuse when it blew the new fuse
  • Haier Master
  • 12,061 Answers
Hi, whenever a Fuse Blows, one should NEVER simply replace it, without first trying to find out why it blew, Fuses DO NOT spontaneously fail EVER.
With a problem like this one MUST call an electrician or a Air Conditioner engineer, as there is a very real danger involved.
Most likely you have some sort of overload, or short circuit to earth.
www.inspectapedia.com/aircond/aircond1123.htm
http://homerepair.about.com/od/electricalrepair/ss/tripping.htm
http://www.inspectapedia.com/aircond/aircond1123.htm
Please find above three websites that you can use to assist you to tracj down your problem if you wish to DIY.
If not then please contact a Haier Service center or local or head office and ask for a referral to an authorised service center /man. Then ask the repairer for a "Quote" before allowing any work to commence, this way you can get an idea of costings etc.
Posted on Aug 20, 2010
  • Haier Master
  • 1,711 Answers
You should also open the comressor comparment, the flash you saw is a result of sparking, you will see a black mark from burn and smoke at the point you have the problem, which is short curcuit that is why you have the blow fuse.
Most possible is the capacitor of the compressor, other posibilities are the compressor it self or even some humitity which evaporate and touch an elctrical live wire.
In any case the problem is electrical and not mechanical and you need a very good visual inspection and also with a tester to confirm the exact part that is short curcuit the electrical wiring.
Posted on Aug 19, 2010
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Light doesn't turn on, nor does it heat up once I turn it on. First time I used it this winter it worked but smelled like it was burning and then stopped working?
sounds like it faulted and burned out some wiring i wouldn't use i would get it looked at to make sure all ok as it may now be elecrically dangerous, if that burning smell, smelt like rubber i'd say definatly electrical but without seening it to hard to say
Nov 20, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Smelt burning smell in the morning stopped cooling
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Sep 04, 2009 | Kenmore 53542 / 53544 Side by Side...
Broken wire from wire housing to top control panel of AC Unit
bad stuff dude, you are going to pay about the same for the part as the unit, unless you learn to bypass that and put it on a light switch, black wire to fan and black wire to compressor on one side of the light switch on the other side the "hot" wire bringing power in, best of luck
Aug 10, 2009 | Heating & Cooling
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
I heard lots of clicking, smelt a vague burning smell, then machine stopped
IT SOUNDS LIKE A PROBLEM WITH THE MOTOR,WIRING, OR TIMER. SOMETIMES THE TIMER MOTOR WILL START CLICKING AFTER IT GETS SOME AGE ON IT. IT IS UNUSUAL FOR THAT TO CAUSE YOUR PROBLEM. THE SLIGHT BURNING SMELL COULD BE THE MOTOR. IT MIGHT HAVE TRIPPED THE OVERLOAD ON THE MOTOR FROM GETTING TOO HOT. AFTER IT HAS COOLED AWHILE, THE OVERLOAD SHOULD RESET ITSELF. YOU MAY WANT TO ADVANCE THE TIMER TO SPIN AND SEE IF IT WILL RUN NOW.
SOME RETAILERS OFFER NO CHARGE ON THE SERVICE CALL IF YOU END UP BUYING A NEW REPLACEMENT APPLIANCE FROM THEM. ASK AROUND.
IF YOU GET THAT DEAL, IT'S TO YOUR ADVANTAGE TO CALL FOR SERVICE. IF HE FIXES IT, YOU HAVE YOUR WASHER READY TO GO, IF NOT, AND YOU BUY A NEW ONE FROM THAT RETAILER, NO CHARGE FOR THE SERVICE CALL.
Apr 04, 2008 | Maytag MAV6300 Top Load Washer
Buzzing noise - loud
check for dirt in the air gap that is formed between the electromagnet and the contact form. if there are any shading coils on the magnet check for a broken one.
Dec 30, 2007 | Dayton U33/U32 Utility Heater
Heating & Cooling Logo
88 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
