Question about Samsung ML 2010 Laser Printer
I cannot run 110# card paper anymore. - Samsung ML 2010 Laser Printer
  • johns060 Aug 25, 2010
    I will have to take some time to apply the solution. I may be back with another question, but this is a good legitimate answer. Thank you.
  • Samsung Master
  • 4,924 Answers
In this printer ..the use of special paper is made on manual feed only ...and before that open the print software ..on the paper tab ..and select the tip ..and the dimensions of the paper..
remember ..the feeding works one at the time from the manual feeding tray only..
Posted on Aug 25, 2010
Flaherty@nbhealth.org I am trying to print on 110 lb cardstock and It keeps geeting stuck. I can't seem to find where I should change the paper type. Please advise.
Use the hand feed tray on the right side. When you put paper in this tray it usually will ask you to set the paper type. 110 lb. card stock is EXTREMELY difficult to copy onto. It might be better to bring this particular job to a copy center. This type of stock will put serious wear on your machines drum. Drums cost big money. Good luck.
Jul 15, 2011 | Minolta bizhub 200 Copier
We are trying to print on a card stock ,110 lb. , 8.5x11 Paper keeps jamming. Will this printer work with card stock?
It will only work if the printer supports feed through from the back. If the paper has to go in the same side of the printer that it comes out it will jam.
Mar 20, 2011 | HP Officejet J5780 All-In-One InkJet...
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
I want a print on card thickness paper , will a hp-5600 series print ?
Theoretically yes, but it's too close to limit. Try, but you have a 50% chances of paper blockage inside the unit.
Nov 29, 2009 | HP Officejet 5610 All-In-One InkJet...
What is the heaviest weight paper I can feed through my Office Pro 7680?
Aug 09, 2009 | Office Equipment & Supplies
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Samsung ML 2010 Laser Printer Logo
93 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
