Question about Maxent Televison & Video
Maxent 42 inch plasma tv, no picture but with sound
  • rethommes Aug 20, 2010
    what is a picture board? Can I easily replace it myself and approximately how much?
  • Maxent Master
  • 11,800 Answers
That means that either the video processor or the power to the plasma panel or the video final is gone. The only way to know it for sure is to take the cover off and testing the parts. Start by checking that both Vs (around 200v) and Va (around 70v) are present at the source, then check that the video final powered and is getting the signal from the processor and finally check everything in between. If you don't know how to do that (or what to do next if one of the voltages isn't there) then call a repairman, there's nothing more you can do to it.
Posted on Aug 20, 2010
  • Maxent Master
  • 6,993 Answers
is your TV connected to a satellite box/receiver? If yes, check the video wire that connect from the box to the TV.
Or You can connect the TV to a DVD player and observe if there will be any video display. You can as well use another video wire for the connection in order to be sure its not a wire fault.
Also, Check you local stations such as channel 1, 2, 3, 4.... from your TV remote if there is no display, then it means your TV is having picture board fault.
The picture board of your TV might be defective, that's why there is no picture. You might have to replace the picture board of your TV in order for it to display again.
Good luck.
Posted on Aug 19, 2010
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
Tech4lfe
  • 38 Answers
SOURCE: Parts for Maxent 42" Plasma TV
The TV was made by LG. You should be able to google an LG distributor or try ebay. The 953 is readily available but the 917 may be hard to find. Won't be cheap for new ones, around $350-$400 for both unless you can find used.
Posted on Mar 06, 2009
  • 13 Answers
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
  • 12 Answers
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Posted on Jul 07, 2009
Maxent 60 in lcd tv flickers
I had the same problem with my 50 inch Maxent, found a solution on the internet that seemed too good to be true, but I replaced a part that cost me $1.38 at Radio Shack and my tv is as good as new. Go to this link for details and even includes pictures. All you need is a scredriver (to remove back cover) and a soldering iron - repair is actually very easy. Good Luck!
http://www.avsforum.com/t/595430/maxent-50-plasma-mx-50x3-official-thread-do-not-post-prices/2130
Oct 18, 2012 | Maxent MX42X3 42 in. HD-Ready Plasma...
No picture or sound on 60 inch samsung plasma 550 TV
The power supply regulator board should be checked. Check this link, and select the site named 'Electro-help'. All details are described there in detail.
Jul 30, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX42X3 42" plasma Monitor..
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
Jun 03, 2011 | Maxent MX42X3 42 in. HD-Ready Plasma...
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
Has sound but no picture
Sorry to say - it sounds like the 'pop of death' - If you got this from costco - give them a call and see if you can claim warranty (or the manufacturer).
Dec 06, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Feb 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Need assistance on how to repair a plasma tv with no picture but sound
This site is BOGUS.
Invites you to post problems and "Ask an Expert" then wants you to pay a fee or you are SOL. Won't recommend and Won't be back
Jun 29, 2008 | Maxent MX-42VM 42 in. Plasma HDTV
Maxent 42' Plasma sound but picture looks like red, green and whites digital specks
the color card in the plasma is not okay.ihad the same problem and fixed it.
Apr 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Televison & Video Logo
648 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
