Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
Looking for a Manual for Homelite Line Trimmer UT20006. Need to know the spark plug gap.
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Posted on Jul 05, 2009
wilsodfarm
  • 986 Answers
SOURCE: How much gap should there be between the ignition
The same thickness as a buisness card work great
Posted on Sep 05, 2009
  • 653 Answers
SOURCE: Homelite trimmer UT20832
The gap on my 18 year old Homelite ST-185 is 0.025. Since they are still using simple and reliable magnetos, yours should be the same.
Posted on Jun 27, 2010
Check spark?
Benjamin, remove spark plug, attach plug wire onto plug, hold end of plug against cylinder head or a metal fastener that you know is going into engine for good ground. Make sure engine switch is in the on position, now pull engine over, observing the gap in plug for spark. If no spark get a new plug and try.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check for Spark Plug Fire in any engine
How to Check the Spark Plug of Trimmer or Edger
Homelite String Trimmer Won Start No Spark
Jun 17, 2016 | Garden
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
Need coil mag air gap for homelite model ut20006 line tremer
You can set the air gap for the coil with a business card used as a thickness guage.
Sep 06, 2011 | Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
The sparkplug RCJ6Y can you tell what the gap is Thanks
The gap for a similar Homelite is .025". I didn't find your exact model. I think you have the 26cc engine. Here is a user manual from similar models. Spark plug information is on page 16.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
You will need Adobe Reader installed on your computer to view this manual.
Oct 05, 2010 | Homelite Mighty Lite Lawn Trimmer
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a practically new Homelite String Trimmer (model #UT20006 25cc) that has been sitting in the box in my mother-in-law's closet for over 3 years. It will start up like a charm. Fairly easy to crank in...
If all those items you mentioned are ok, then check the Air filter! If it's been sitting around, it may be plugged up or it may have insects that have built nests inside...
Also, there should be a fuel line back to the tank for pressurizing the system... Make sure the gas cap is tight, and the return line is snug in the tank.
Jun 03, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Spark plug gap
Jul 05, 2009 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
88 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
