Question about Philips GOGEAR SA6045 MP3 Player
I 've got virusses on my philips, i've format it through linux but the message from philips is "file system error" so what should i do? thanks more
  • 210 Answers
For sure, the file system is corrupted and is the cause of your woes. The fix lies with the Philips Songbird software. If you do not have Songbird, download it for Windows or Mac here:http://www.usa.philips.com/c/mp3-media-player/22126/cat/en/#/difference/philipssongbird. There is currently no version for Linux. So, a Windows PC or Mac will be required for the fix.
Once you have Songbird installed, launch it and select "Repair my Philips device" in the Tools menu. Select your device and follow the instructions specific to your device. For example, instructions for the GoGear Vibe are to disconnect the device, power it down completely, and hold the volume-up key during and after USB connection until the message window disappears.
If the repair utility endlessly indicates it is checking for updates, you are likely using an out-of-date version of Songbird - probably the one that came with your GoGear. If this describes your situation, launch Songbird and select "Check for updates" in the Help menu. This will at least get you upgraded to version 1.9 (currently), even though the latest version is 1.11 (currently).
Instructions that came with some older versions for connecting GoGear in repair mode were incomplete. They left out a crucial step of turning off the GoGear and waiting for it to power down completely before reconnecting in repair mode. Newer versions of Songbird include the ability to reformat the device, reset the device, and to get progress updates during synchronization.
If you've found this information helpful, please indicate as such.
Posted on Apr 04, 2013
  • 864 Answers
Ok what you need to do is repair the firmware. The file system error has nothing to do with a virus. It means the firmware has become unstable or corrupted through any series of events.
by following this link http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/37&scy=us&slg=en you can download the software/firmware needed to reflash the device and this should solve all of your problems with the file system error. Ensure that it is the correct model number and download the files and flash the device by following the instructions on phillips website.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Posted on Aug 19, 2010
I have an error message in my iRiver and unable to use it anymore. The error message I'm getting is: Boot Failure System file has an error. To solve the problem, connect the device to compute
If it is an older model like H10, it used a a micro hard drive which may have failed mechanically. Those old hard drive devices were susceptible to shock failure due to drops. In some cases you may be able to replace the failed hard drive with a compact flash card - I believe they used the same connectors and pin outs. If it is not a hard drive model, can you get it recognized by windows drive manager to try to reformat it. There's a linux based program G-Part Ed. It's an ISO file, burn to cd or put on USB and boot pc to the cd or usb to launch linux and the software then see if it will recognize and format it as an external drive. Gibson research used to make spin rite that was able to fix some hard drive problems, might work on flash memory too.
Jan 02, 2015 | iRiver Audio Players & Recorders
Tip
Linux System not Booting: A Troubleshooting Session
<span>In a recent days in our lab I've got a with Linux file system. <span> </span>Our lab used Redhat Linux 5.3 Enterprise version. Redhat Linux is an Unix based Operating System and It based on Ext3 file system</span><br /> <span></span> <br /> <span><span>Problem of Linux:<span> The systen cannot access internet. It shows the license expiry error notification. Some</span></span><span>time it doesn't detect the hard drive. Some time the pc can detect hard drive but the Linux started with some errors of file system. Finally the file system of the OS getting crashed and can't boot. At GRUB loading stage it become restarted.</span></span><br /> <span><span></span></span> <br /> <span><span><span>Solution or Troubleshooting: </span><span>If I replace the hard drive cable It detect well and start OS also. Then the pc can detect hard drive but the Linux started with some errors of file system. Then I discovered that there is a problem with OS.<span> </span>Though formatting can solve the problem but that needs a backup of important data. This is time consuming and risky. So I thought to repair the file system</span>.</span></span><br /> <span><span><span></span></span></span> <br /> <span><span><span>At first I'm trying to login in single user mode and repair the file system. I have tried to login by pressing "s" beside kernel at startup in single user mode. But the system doesn't boot. Then I'm trying to repair the OS by RedHat Linux CD. I <span> </span>Insert the CD and select rescue mode by pressing "F5" key. Then I got the single user mode. After that I check all file system sequentially. </span></span></span><span><span><span>/etc /passwd, /etc/shadow, /etc/securetty, /etc/pam.d/login. Those file was wrong. I updated those file by correcting. Then I update the auth config file. After that I boot the system again. But now also it don't get start. Then I rescue the grub by grub-rescue and also update the kernel. After the total process I'm tried again to login from single user mode in root and It get logged. After that I reboot the system and tried to login. Finally it logged in successfully and run properly.<img src="alokerdas.jpg" /></span></span></span>
on Jan 15, 2011 | Computers & Internet
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
My 16GB Kingston DT101 G2 has 14GB free space in it. But when I tried to copy a 4.5GB movie file into it, it gave me an error message saying "The disk in the destination drive is full. Insert a new...
usb drive likely pre-format in fat32 for compatibility to "old" version of windows linux and mac. but fat32 can't handle file bigger than 4gb
try format it to ntfs file system.
Jan 30, 2011 | Computers & Internet
Error message if trying to save files larger than about 4GB.
The Buffalo Ministation hard drive comes with a default FAT32 file system. This file system is used for compatibility with Windows, MAC OS X, LINUX, etc. The file system does not allow files to exceed 4GB. To save larger files, the disc must be reformatted. For Windows, it should be reformatted to NTFS.
Jan 06, 2010 | Computers & Internet
I have a Philips Gogear SA23XX its 1GB. i have switched to linux(i still have windows on a partied drive) i plugged in the player and when i look at the mp3s on there. it shows them all locked so i clicked...
Look at the mount options, it sounds like your linux distro may have mounted the aria's filesystem as read-only or as a another user (root perhaps?). You're going to need to use the shell prompt to figure this out.
Jul 10, 2009 | Philips GOGEAR SA6045 MP3 Player
Mp3 player wont play music, says file not formated
The file not formatted message is not an error that a repair will fix.
The songs that you have loaded onto the player are in a format that the player does not support. Do yourself a favor, and only download files that rae in mp3 format - they will never give you problems, error messages, require long explanations, etc.
-Tha Mp3 Doctor
Jan 09, 2009 | Philips Sport Personal CD/MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
137 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
