Question about Bosch 24 in. SHU43 Built-in Dishwasher
Changing the cycle time
How do I get the dishwasher to a lower time than 2 hrs???
Sorry, but you are not exactly clear. Timer is pre programed to the program selected. the lighter the wash the less time it will take.
Posted on Jun 10, 2008
Dishwasher runs for 2 hrs when cleaning is this normal?
The average cycle time range of 80 minutes at the low end to 145 minutes at the high was reported in Consumer Reports article on dishwashers.
Most of the dishwashers rated were in the 110-125 minute range.
So i think what you are experiencing is normal only..
Aug 31, 2010 | Dishwashers
Whirlpool GU1200XTLB1 dishwasher takes over two hours to finish cycle. is there a reset? or some other problem?
Check the wash cycle mode setting you have selected. Refer user manual. Two hrs cycle looks to be OK.
Check the water inlet flow also. Clean strainer. Slow fill of wter will lengthen the time of operation.
May 22, 2010 | Whirlpool GU1200XTLS Stainless Steel...
Brand new dishwasher does nothing but wash & rinse
Time for warranty replacement or repairs! Good luck!
May 14, 2010 | Frigidaire PLD4375RFC Dishwasher
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our less than 1 year old Whirlpool dishwasher model DU1145XTPQA is taking as much as 2 and 3/4 hrs. to complete the entire dishwashing (normal)cycle. This is much longer than it used to take.
Contact Whirlpool service immediately to get a service call scheduled before the warranty expires.
Most dishwashers that begin taking longer to complete the cycle have a failed heating element but that also normally means that the dishes do not get fully clean and the glassware has a film on it after the cycle ends.
Good Luck!
Apr 07, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
THE DISHWASHER STAYS IN THE WASH CYCLE
Check to see if the water is getting hot during this time, if not then the heater is probably not working, could be bad heater, bad door switch or bad heater relay on the control board.
Dec 14, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
148 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
