Question about Microsoft Xbox 360 Console
Xbox360 unplayable disc message
Is there anyway to fix this. I also opened the front and cut the sticker. If I cant fix it where would you recommend sending it to get fixed. Ballpark price to get fixed?
  • Anonymous May 03, 2008
    I originally had the three rings disease and fixed it myself much at my dismay that something else would go wrong. Now the xbox works and plays for a minute and then freezes up. I have also gotten the unplayable disc message as well. If there are any suggestions as to what to do I would appreciate the help.
  • Mike Waldron May 11, 2010
    is this just 1 game or several.
    Also have you tried A Music CD ?
    Mike.
How flash the new drive after purchasing it
Posted on May 25, 2008
  • 44 Answers
If u get ureadable disc then is a lens problem i recommend you going to ebay or www.divineo.com to purchase a new lens u need to open system up to see your model of drive you have do not buy a new drive this will only worsen the problem feel free to email psx2king@gmail.com
Posted on May 14, 2008
My xbox360 game mercenaries2 does not work it allways turns of.
IS it giving you an error message?
If the 360 is shutting itself off, then this has nothing to do with the game, and you have some form of power supply problem. Try a different game. If it still does it, you most likely need a new power adapter. If you are getting an error message (unplayable disc/dirty or damaged disc) Then the most likely cause is your optical lens in the DVD drive is dying.
Jan 07, 2010 | Microsoft Xbox Console
Disc is stuck in my sons xbox360, is there anything i can do without having to send it to germany, im uk, thanks
Hi Jim,
I can see how your son might have felt missing his fav games for the day, apparently the only possible solution would be to open the XBOX and removing the disc manually. Make sure that the warranty sticker is not torn or scratched while you do this process.
And if you are not confident then I would recommend you to fedex it to Germany Hope this helps
Nov 05, 2009 | Sega The Club - Xbox360 for XBox 360
Keeps saying open tray when game in inserted..when system starts to run...it says either open tray or disc unplayable ...mlb 2k9 xbox360/live
check around the disk tray for dust and use a vaccum cleaner to clean it, then use a wet cd lens cleaner with cleaning fluid a few time.
This should cure the problem but it might be that your drive is dead
Oct 25, 2009 | Microsoft Xbox 360 Console
The error message "Unplayable Disc" for the xbox360
$300?!? anyways. this came straight from a store right? normally this only happens when you copy the game on a disk and play it. Contact Microsoft.
Sep 24, 2009 | Microsoft Xbox 360 Console
It only plays Normal Xbox games
The open tray and unplayable disc is because the lens isn't strong on the drive and needs to have a Pot calibration done to it to make the lens signal stronger. That should fix the open tray/unplayable disc issue. I have done this to quite a few drives and all have been working fine since.
Jul 12, 2009 | Microsoft Xbox 360 Console
When i put a game into my xbox360 it reads unplayable disc.
Try blowing in the cd drive to get any dust off of the laser that could be one of the causes if it doesn't work then send it into microsoft if warranty is good if not then you try poping open the 360 yourself and try look at the disc drive but more than likely if it doesn't read anything thing then your better off at getting a new disc drive, that includes if it doesn't read dvds. let me know if cant fix it and you don't want to buy a new cd drive.
Jul 01, 2009 | Microsoft Xbox 360 Console
Xbox360 will not read some games sometimes or will start then go
The "Unplayable Disc" error has also been heavily reported. The error appears to be limited to the Hitachi-LG CD/DVD ROM drives that replaced the earlier Toshiba-Samsung drives. The error message is preceded by a loud series of grinding noises and the system returning to the dashboard. From that point forward, any disc that is put in the unit will result in the "Unplayable Disc" error (although if the user was to eject and close the disc tray in quick succession the disc may sometimes play). In the majority of cases, this error is caused by the adhesive that holds a small magnetic washer heating up and allowing the washer to affix itself to the metal top of the drive. After this occurs, the system can no longer spin the disk as necessary. Numerous fixes are available on the internet, but all involve opening the console box. Opening the console will result in the unit's warranty being voided. Microsoft will fix the error for a fee . Included in the repair fee is one additional year of warranty coverage.
if you dont give a damn about warranty
open it up and clean the drive and wipe everything down with a q-tip. and replace it back
thank you
Apr 07, 2009 | Microsoft Xbox 360 Console
Unplayable disc error on xbox 360.
goto youtube and search for unplayable disk error fix.
Jul 12, 2008 | Video Game Consoles & Games
My xbox360 doesent read anything it says unplayable disk
hi there, what you can do is maually clean the lens , free it frm dust and residue. be sure to clean it thoroughly so that it will not be damaged and wont read anymore cds.
hope this will hlp you.
Jan 28, 2008 | Microsoft Xbox 360 Console
Unplayable disk error and sometimes noisy
Go to Youtube and look up opening XBOX 360. There are lots of videos and tutorials explaining how to open up your XBOX. JUST REMEBER TO KEEP THE SILVER STICKER INTACT SO YOU CAN PUT IT BACK AND NOT VOID YOUR WARRANTY
Oct 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
