Question about Lexmark T520 Laser Printer
The Performing self test message stays on and will not boot the printer
  • LXK Chris
    LXK Chris Aug 19, 2010
    Try to boot the printer without options, e.g. drawer, duplex, etc., and remove it from the network, maybe this is a problem with one of the options. If problem continues, system board and the op panel may need replacement.
  • 1602 Answers
SOURCE: Lexmark X342n Exception:ABT when booting up.
GO ON LINE TO CANON AND TYPE ON LINE OR ADDRESS BAR
CANON X342N BOOT UP ISSUES
OR
CANON X342N EROR MESSWAGE R9:0X000000000
OR
CANON X342N FREEZES AFTER IT STARTS
I THINK YOU WILL FIND WHAT YOU ARE LOOKING FOR BUT IF NOT YOU CAN CONTACT ME AGAIN
ROD IS THE CANDYMANGANDY
Posted on Feb 04, 2009
SOURCE: i have hp laserjet 1100 printer when i switch it on it is not performing its startup test or self diagnosis test when it starts
...so the "error light" lights right away? Almost surely a fuser error, but regardless, it is not worth fixing when you can replace it for under $100
Posted on May 17, 2009
  • 53 Answers
SOURCE: When Switched on printer shows performing self
seems as if the hard drive is shot
Posted on Nov 30, 2009
TechSaver
  • 93 Answers
SOURCE: stuck on self test message at Power Up
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
Posted on Jan 22, 2010
  • 17 Answers
SOURCE: i have a lexmark t520 printer, i just installed a
Take out the Printer Cartridge and shake it and put it back into its slot.
Posted on Jun 08, 2010
How to fix Error 900.43 service RIP soft ware
Reset Factory Defaults.
1. Turn off the printer.
2. Press and hold and .
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
If that does not fix this issue,With Error Code 900 displayed, press and . Post the complete list of Sub Error Codes on the display.
Jul 27, 2015 | IBM Infoprint 1532 Laser Printer
8550 cold reset
Performing a cold reset 1 Print a configuration page to record the previous printer settings. 2 Turn the printer off. 3 Hold down GO while turning the printer on. Release GO after COLD RESET appears on the printer control panel display. COLD RESET (in English) appears on the display for one second to verify that the key sequence has been recognized, followed by the power-on self-test message. Once the power-on self-test is finished, the message RESTORING FACTORY SETTINGS displays in English.
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
My faxes are not printing. They seem to be connecting but they won't print.
Tips and tricks For the LEXMARK X342N
1) Faxes won't print.
Try this first....
Press <MENU> then <*> <#> on the keypad
Press <UP ARROW> and see "UTILITIES RESET SYSTEM"
Press <CHECK MARK>
and see RESET SYSTEM
Press <DOWN ARROW> and see (FAX NVRAM)
Press
<CHECK MARK> should reset the fax memory.
Try this second....
Press <MENU> then <*> <#> on the keypad and see "SERIAL NUMBER"
Press <CHECK MARK>
Press <DOWN ARROW>
<DOWN ARROW> <DOWN ARROW> and see (ERASE FFS)
Press
<CHECK MARK> should reformat the fax memory.
It will reboot. Occasionally says the FAX NVRAM is bad
when performing the boot-up self-test and corrects the problem.
2) PC LIFE WARNING message
After replacing your photo conductor kit you need to reset the "PC LIFE WARNING" message. With the front toner door open press and hold the red <STOP> until you see the "RESETTING PC COUNTER" message
Mar 15, 2010 | Lexmark X342n All-In-One Laser Printer
Start up printer stays in o5 self help test
Should sit in 05 Self Test for a minute or so... then continue booting up.
If it sit there forever, then switch it off and remove the JetDirect card (if fitted) and try again.
Then remove the RAM modules and try again.
If it starts up, try the part you removed back in the printer again. If the fault returns, you have found the faulty part. Remove or replace as required.
Mar 01, 2010 | HP LaserJet 4 plus Printer
Stuck on self test message at Power Up
Jan 22, 2010 | HP OfficeJet 7110 All-In-One Thermal...
How do you reset the mainentance count on Lexmark t640 printer.
Enter the Configuration Menu:
2. Press and hold (check) and (right arrow).
4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel shortly.
5. Scroll to Reset Maintenance Count from the Configuration menu and select.
6. Press (check) to reset count.
Oct 08, 2009 | Lexmark ImageQuick SIMM (15W0000) for PC,...
HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | Dell 1720dn Laser Printer
OR
OR
Sep 26, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark T520 Laser Printer Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
