Blur i have a smartcam 2.1 but when i try to use the camera for video conversations or something the image is all blurry, how do i get this to focus and give a good picture? camara web
    Scholar:
  • 46 Answers
It all depends on the quality of camera i think you should buy a good camera
Posted on May 10, 2008
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
I have a JVC GZ-HD300 Hard disc video camera and when using Everio Mediabrowser which comes with the camera download to convert my videos the conversion leaves the finished video blurred
Hi.
If the original footage was sharp, that means that you are probably using wrong compression parameter or format on Everio, while doing conversion.
If the source movie was blurred instead, try using the Advanced Image Stabilisation option, usually available in new JVC HD camcorder menu.
Everio has different quality settings. Each time you increase compression you lower quality.
Also ensure that the camera was not in a low definition setting.
Regards.
Ginko.
In addition
Jun 12, 2010 | Cameras
Blurred images
i beleave on auto, the a75 has auto focus, there is a 1/2 second focus time before the picture is taken, enough to blurr the picture
Jan 03, 2009 | Canon PowerShot A75 Digital Camera
Blur
There is an adjustment lens infront of your webcam. Try to rotate it slowly clockwise and if you reach the end and still blurry, rotate back slowly until the imag is acceptable.
Hope this helps.
May 02, 2008 | Computers & Internet
Apitek 1.3 Images are blur at faces
Sounds like an autofocus issue. Either the camera is malfunctioning, or it just may be seeing something else it thinks it should be focusing on. Pictures thru glass often focus on the glass even tho we look thru it, watch for reflecions. Anything between you and the person may throw the focus off, like taking a picture of someone thruogh a doorway. If the face is off to the side the camera may be focusing on the center. If your camera has a two-click snap button, try holding only the first click and see what it focuses on.
Feb 01, 2008 | Aiptek Mini PenCam Digital Camera
Optic viewer blurred image
Not much that you can do with that, try adjusting the small focus lever on the underside of the viewfinder, as this might fix the blurred image, your lucky that you didn't, break something on the camera.
Jan 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
JVC camcorder with blurred images
It could be an issue with the dioptre adjustment: 1 Set the Power Switch to ?A? or ?M? while pressing down the Lock Button located on the switch. 2 Make sure the LCD monitor is closed and locked. Pull out the viewfinder fully and adjust it manually for best viewability. So slide the rubber eyecup toward you. 3 Turn the Dioptre Adjustment Control until the indications in the viewfinder are clearly focused. The control is a litttle knob on the sied of eye-piece. While looking through the viewfinder, turn the knob until it is focused. Hope this helps. NewMediaMan
Jun 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Why are my flash images out of focus?
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
47 people viewed this question
 Grubhead
Grubhead
