Question about GE DWSR483EBWW Electric Dryer
How do you take it apart to replace a belt - GE DWSR483EBWW Electric Dryer
  • GE Master
  • 8,220 Answers
Unplug it, open the door, remove the screw holding down the top. Then remove the front and yank out the drum. Make sure the new belt is not twisted. Check the slides and rear bearing for wear.
Get a friend to help you hold the idler while you place the belt on the idler and motor. Pictures and more HERE.
Posted on Aug 20, 2010
I think the belt broke or came off. Sounds like it would be easy todo. what is the best course to take? I thought that taking it apart to validate and confirm then ordering the belt and doing it myself....
Just pull it apart get the belt out & take it to a belt shop, care fully replace the belt just be carefull the belt will also go around a spring loaded pulley so when the belt brakes the motor will shut off - pretty easy 1/2 work - save heaps.....
Jun 13, 2011 | Dryers
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
How do i replace the belts
I supposed you have a new belt. Take a screw driver take apart the screw and start taking apart the pieces where the belt is and just put it.
Dec 04, 2010 | Vacuums
Leaking from water pump and timing belt is slasded
If you are losing antifreeze out of the water pump, then that is a sympton telling you it's time to replace the water pump. When you say the timing belt is slashed up, do you mean the serpentine belt that runs the power steering pump, ac pump, alternator, and water pump or have you actually torn the engine apart enough to see the timing belt?
If you in fact mean the serpentine belt, chances are it's torn up because either antifreeze got on the belt making it slick enough to get off track and when they get off track, they can get slashed up pretty quick.
Good Luck
Dec 16, 2009 | 1995 Mitsubishi Eclipse
AIWA F770 cassette deck belt replacement
you just have to pull it apart until the belt can fit straight on there are no short cuts make notes as you pull it apart for the reassembling
Nov 06, 2009 | Aiwa Audio Players & Recorders
Belt broke cant find where to take apart to replace belt
Most dryers can be taken apart on the back. Take out the screws holding the rear plate on and you should see the motor and pulleys. It's always good to keep the back oof of the unit until you test it once. The belt could be getting broken or just slipping off due to overloading the unit. Over time, this can severly damage the rollers and put too much tension on the motor assembly. Hope this helps.
May 24, 2009 | Dryers
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How do you take apart a hoover brush n wash to replace the belt
Generic problem for all Vacuums
How do you take apart?
How do you take apart a Hoover brush n wash to replace the belt?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
On a Hoover brushroll there are 2 types, wood and metal, and the metal can be washed with water and the wood should only be wiped off, knowing the name brand of the vacuum most of the vacuums the belt change is done by removing the bottom plate and exposing the belt, 1st hook the new belt around the brushroll and then use a screwdriver or similar with a bent hook on the end and then pull or hook the belt on to the motor pulley and then track the belt to make sure the belt stays on, then re-install the bottom plate and turn the vacuum on to test to see id the belt was installed correctly. The other is to look for 2 or 4 screws on the bottom and then remove the top cover and follow the instruction listed above without the bottom plate. A belt change should be done every 4 to 6 months on regular basics and to keep the belts in the refrigerator to keep them fresh.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874
Apr 21, 2008 | Vacuums
HP Deskjet 722C printer belt has frayed and come apart
Dear DIOGENES2001 ,
Yes , please contact nearly Authorised Service centre for genuine spare .
Cheerup
Mar 04, 2008 | HP DeskJet 722c InkJet Printer
GE DWSR483EBWW Electric Dryer Logo
312 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
