Question about LG Computers & Internet
I have an LG Flatron L227WTG 22 inch monitor. It is making a loud buzzing sound while on. What can I do to get it to stop?
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
ginko
  • 19396 Answers
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
Tyranny
  • 21 Answers
SOURCE: I have a LG Flatron 22", LCD monitor, model is W22345. dilemma: after sleeping the computer for the night, as I have been doing for the past 8 months that the computer and monitor has been in my owne
Check the video cable,replace them, and if didnt work, try to reset the config stored on the settings of the monitor (usually by menu).
Some electronic problems could do the same simptom. check the manual for hints.
Good luck
Posted on May 24, 2009
wagyp
  • 86 Answers
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
Posted on Jul 26, 2009
bilua
  • 102 Answers
SOURCE: when i turn on my flatron 22 inch monitor the blue
HI,
your monitor is not working properly, bcoz monitor data cable no connected properly into the System or any internal problem in your monitor.
Thanks
Posted on Aug 15, 2009
Flatron w2252tq
Hello Shan,
The W2252tq uses the AIP-0165 power supply board that is also used in the L227Wtg series LG series monitor. This board is known to have issues with the filter capacitors going out. When they go out it causes the monitor to not power up just lie you have. Here is a picture of the power supply board in the unit and below is a link to a repair guide for the L227Wtg, since it has the same power supply the repair guide for the board will be the same.
Here is the repair guide.
http://www.ccl-la.com/blog/index.php/repairing-a-lg-l227wtg-pf-22-monitor-no-power/
Sep 24, 2012 | Gateway FPD2275W LCD Monitor
LG Flatron L227WTG goes to black/dim
Your problem is a very common one. That model uses the Aip-0165 power supply board and when the capacitors on the board start failing if can't power up the monitor correctly so you get a dim picture, after continued use the monitor will fail all the way. Here is a link to a repair guide that will show you what to look for and replace on the power supply board to get it back up and running again.
I hope this helps, if so please rate my solution.
Mar 25, 2012 | LG Computers & Internet
Hi, I have an LG Flatron L227WTG monitor. I have 2 computers on my desk. When I plug the monitor directly into my home computer, the monitor works just fine. When I plug it into my work laptop (via a...
Hello, maybe you've got to switch the output from your laptop screen to the external screen, if so, it will be by pressing and holding down the Function button and at the same time pressing one of the Function keys (at the top of your keyboard). On mine, (an HP) it's F4, but you'll see a symbol on the correct key that looks like a screen. Regards, nicam49
Jul 13, 2011 | LG 22" FLATRON LCD Monitor
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
I have a L227WTG and it will noit turn on, power button just keeps flashing and will not tuirn on the monitor. Help?
Unhook the monitor from the pc. Then go ahead and turn on the monitor. If the same thing happens then its an issue with the monitor and the monitor would have to be replaced. If the monitor turns on after unhooking it from the pc then its an issue with the pc.
Sep 22, 2010 | LG 22" FLATRON LCD Monitor
Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | LG 22" FLATRON LCD Monitor
When i turn on my flatron 22 inch monitor the blue power button comes on for a second then goes out,it will not stay on.
HI,
Thanks
Aug 15, 2009 | LG 22" FLATRON LCD Monitor
My LG Monitor screen is flickering at random and it's very annoying. - model: Flatron L227WTG
Try adjusting the resolution of your LG Monitor screen to lower one... by going to Control Panel>Display then click Settings tab then look for Screen Resolution adjust to less. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
171 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
