Question about Fujitsu LifeBook E8310 Notebook
Fujitsu LifeBook E8310. Voltage fluctuations followed by stopping of the leptop. Phoenix BIOS password reset on request. I never set the activation password. Syk for suggestions!
  • 3422 Answers
SOURCE: Fujitsu Lifebook C2210 laptop
HI,
Please CLICK HERE this site has got some passwords which can help you out.
Goodluck..
Posted on May 25, 2008
mdsaeed67
  • 849 Answers
SOURCE: fujitsu n series n3530 lifebook
you need to open your laptop, you will find it on the motherboard, near the battery you will find the CMOS reset jumper or switch.
Posted on Oct 22, 2008
  • 159 Answers
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Posted on Dec 07, 2008
  • 15 Answers
SOURCE: forgot bios password
You might have to remove battery cell which is located backside of every laptop and then on your laptop try to access bios if it works then off the laptop attach the cell again in same position and enjoy bios without password.
jrpitale.
Posted on Feb 17, 2009
Geekman
  • 32281 Answers
SOURCE: Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Posted on Jul 06, 2009
Phoenix password
Contact Fujitsu Support for a one-time BIOS password.
May 22, 2013 | Computers & Internet
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Fujitsu LifeBook E751 bios password
This will not work, all the guys posting here have NOT tried this "solution". Do NOT waste ppl time please! Lifebook E751 has a security chip and the password will NOT be reset even if you physically rewrite the BIOS on a BIOS programmer.
Oct 04, 2012 | Fujitsu LifeBook E751
I have a Fujitsu-Siemens Lifebook e8110 which has bios password and I can not reset it. has both the administrator password and user. user password can only view the BIOS. administrator password I need to...
User and Administartor passwords are only for your OS. Windows® for Example
To reset your BIOS password, you must disconnect your laptop-battery. Wait a few minutes, and put it back in. Now your BIOS password has been reset and you can access your BIOS again.
Jun 02, 2011 | Fujitsu LifeBook E8110 Notebook
How do i reset a fujitsu lifebook e8310 that is running with window 7 back to its original factory setting and wipe everything off.
In that link there is step by step solution for that. . . you will need all the CD's that came with your laptop and follow the instructions . . . if you need more help don't doubt to write again. . .hope it help you. .
The instructions are on page 61
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/E8310_UG_B5FJ-3971-01EN-00.pdf
Mar 08, 2011 | Computers & Internet
I am trying to recover a Tseries t4210 fujitsu lifebook, but unfortunatly it has a bios password set and the previous owner has now left the company. Can you help in removeing the bios password...
To reset the BIOS password read the information from this link.
Before you open it up I would suggest trying Hiren's Boot CD and Kill CMOS to wipe the BIOS.
Feb 10, 2011 | Fujitsu LifeBook T4210 Tablet PC
Ik heb een E3810 van fujitsu maar er zit een wachtwoord in de bios hoe kan ik die reseten
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Jan 27, 2011 | Fujitsu LifeBook E8310 Notebook
PASSWORD RECOVERY
Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Try these to gain access first. As these may still be active.
Mar 28, 2008 | Computers & Internet
Need password for phoenix bios version 4.0 release 6.0 notebook(laptop)
I can't help with any Back door passwaord BUT I have found a couple of BIOS Password Removers... perhaps ya can just get rid of the "Old" one and ya be all good? I "Googled" the following .... phoenix bios password cracker download ... and got heaps of hits.. So good Luck. www.cgsecurity.org/wiki/CmosPwd www.softpedia.com/get/Security/Decrypting-Decoding/CmosPwd.shtml
Aug 18, 2007 | IBM ThinkPad A21m 2628 Notebook
Locked out
hi follow this you will be set http://www.tech-faq.com/reset-bios-password.shtml good luck
Mar 28, 2006 | Fujitsu LifeBook P2040 Notebook
Fujitsu LifeBook E8310 Notebook Logo
143 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
