Question about Poulan Pro Super Blowervacuum
Trying to take apart to replace fuel hose.taken screws out and lid offvaccum.but will not come apart why.jerry
    President:
  • Poulan Master
  • 1,545 Answers
Sometimes, its easy to miss a "hidden" screw. The plastic case probably has plastic guides for it they may even interlock together. Search again for a "hidden" screw before giving up. You will find more than just one fuel line. Here is how you would replace them if you choose to do so (recommended).
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Aug 19, 2010
How do i dissasemble my Black and Decker Electromate 400
Cold weather can freeze the water that the compressor normally makes, try warming up the unit first.... eliminate the simple problems first.....
Jan 30, 2010 | Black & Decker Air Tools & Compressors
The washing machine is not draining the water away, so i can not get my washing out
It must be the drainage hose, the water cant go anywhere else. The majority of the drainage hose is out of view, unless you've taken the whole thing apart, so it must be blocked.
Hopefully, it will be under warrenty, or you're looking at arounf £70 for someone to come out and fix it.
In the future, every three months or so, put your washing machine on the hottest cycle with clear vinager, and a dash of bleach; this will help unblock any potential blockages.
  1. step 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. Step 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Step 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Step 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. Step 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool Washing Machines
Leaking Fuel tap (petcock)
This sounds like a vacuum lock pet ****. 3 position? run, prime,and reserve? If you have it on pri, You will fuel running or not. If set on run, then you will only pass fuel when engine is running, and of course res. when tank is used up. Is this leak at the valve? or from the tank or internally flowing? Tis should also be a gravity feed fuel system, please correct me if I'm wrong. good luck. Long fuel lines are not prefered on gravity feed systems.
May 20, 2009 | 1986 Honda VT 500 C Shadow
Roper Washer ras6233kq1
defective pump...remove 2 screws on console corners..flip console back...disconnect lid swich harness,,,remove the 2 brass or gold color clips on each side,, now pull cabinet towards you..you see that plastic piece with 2 black hoses replace it...onthejob
Feb 17, 2009 | Roper RAS6233KQ Top Load Washer
1998 Dodge Dakota ext. cab - Fuel line leak at pump
More than likely. Go to any auto parts store and they have a special tool for taking the gas fitting apart. (Very cheap)
Jul 29, 2008 | 2006 Dodge Dakota
AIR FILTER
There is an air box with 2 hoses one going to the intake and one underneath going to another airbox, loosen the clamps and pop off the hose to the lower airbox and remove the 2 10mm bolts holding the top one to the radiator support. There are 2 clips holding the lower box lid in place pop them open rotate the lid toward the rad and remove the old filter and replace it with the new one. The assembly is reversing the order to take it apart I had trouble with this the first time I did it also.
Jul 23, 2008 | 2000 Dodge Caravan
Disassembly
what are u trying to repair on it?
Aug 20, 2007 | Whirlpool LTE6234D Top Load Stacked...
Poulan Pro Super Blowervacuum Logo
245 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
