Question about Ovens
I need to replace the outer black glass oven door panel on our Kenmore stove, has broken and the part is no longer available. Size of panel is approxiamtely 20" X 30", needs to be tempered. I can have fabricated locally but need source of material or better yet replacement part, though numerous inquiries on internet typical reponse is "no longer availabel." Need help.
  • 1 more comment
  • Kelly
    Kelly Aug 19, 2010
    What is the model number and I will see what I can come up with? Kelly
  • michael_a894 Aug 19, 2010
    Kenmore Model #911.3522190
    Part # WB57K5121 "Outer Glass"
  • michael_a894 Nov 09, 2010
    At long last found glass in Hawaii, 1 of 5 remaining, shipping same cost as part. Now need Glass Spacer #WB02X9039, is available, received, does not look at all what I need. I believe I need a small sleeve / shiv that goes in glass to isolate screw from glass as screw goes through glass, need 2. Also need 2" fiber washer, not available though found 1" fiber washer, is surface applied to glass, goes between glass and metal retainer, I need 2. Looking for alternative solutions - duct tape?
    Thank you.
  • Ovens Master
  • 3,740 Answers
If anyone can locate this part I would bet on appliance parts pros:
1-877-477-7278 http://www.appliancepartspros.com/part_details.aspx?part_id=2035287
This door glass was originally made by GE.
You can also try the repair clinic:
800-269-2609
http://www.repairclinic.com/Appliance-Parts?s=t-WB57K5121-%3d%3d
These 2 sources will probably be your best bet. I know it says they are not stocked.
As I said GE made this door originially. You can call their parts line at :
Parts:
Call: 800-626-2002 Start with the call to GE parts first using your WB57K5121 part number. Fingers crossed but as a service tech this is exactly what I would do if I were faced with your situation. Wish you the best and would appreciate any feedback on your search results. Thanks for choosing FixYa. Kelly
Posted on Aug 19, 2010
Removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
The glass outer glass on my oven window broke can it be repaired? It's a Thermador Model# CT227NPRS Serial# 98020093
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 05, 2011 | Ovens
Kelvinator F36 oven door glass measurements
you have to get high temp glass or it will shatter
May 24, 2010 | Ovens
Broken outer panel of glass on cooker door
I found a replacement for my oven on ebay. Be careful, though, because one seller offered one that was the wrong size.
Apr 01, 2009 | Ovens
BROKEN GLASS ON OUTSIDE OVEN DOOR STOVES S5 600MF
You can normally replace the outer door glass independently of any other parts.
Try-----www.espares.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Stoves Premier 600EMa Electric Single Oven
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
Nov 01, 2008 | Ovens
Door Face needed (Glass broke, model discontinued, can't get part)
Linda, if you can't find a replacement door at local used appliance repair shops - check the Yellow Pages - look to see how the door comes apart.  It is probably held together with 6 or 8 Philips screws.  Get the door apart and take out the broken glass.  Call around to see if an appliance repair store has an oven they are discarding that has the same size glass or larger.  If the glass is too big, phone a few glass shops to see if they can 'cut' it down for you.  Some tempered glasses can be cut and sanded down to the precise size you need. Take your old broken glass to the shop to be used as a template. You should be able to get away with this type of repair for $50 if you compare prices. Cheers, Pavel
Oct 21, 2008 | Amana AOCS3040 Electric Single Oven
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
167 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
