Question about Cameras
When inserting new 4gb sd card, camera won't format. camera returns to "memory card required formatting"
  • kakima Aug 19, 2010
    What make and model camera? Some cameras only work with SD cards. Your 4GB card is actually an SDHC card which, while fitting into an SD slot, won't work in it.
  • lorna7793 Aug 30, 2010
    thanks, took it to pc world and was embarrassed to be told it didn't accept hc cards. gutted as reglar sd's are few and far between in 1gb... nevermind. thanks again
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Glad to have been of service :-)
Posted on Aug 30, 2010
My nikon coolpix5700 camera will not format a 4gb memory card is there a problem with my camera
The memory card maybe faulty, try inserting it into an USB card reader and plug it into the USB port of a working computer.
If the computer cannot format the SD card in FAT32 then the SD card id faulty.
Mar 23, 2012 | Nikon Cameras
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
Why is my camera going round and round in circle when trying to format my memory card?
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
Nov 10, 2011 | Kodak EasyShare DX7590 Digital Camera
My c703 won't format a new memory card. The old memory card is full (2GB), but I've tried two NEW Lexar 4GB cards and neither will format. Help!
Hi, The reason neither 4GB card will format is because that camera is only able to support, at most, a 2GB card. I'd suggest returning the 4GB card and getting another 2GB one.
May 13, 2011 | Kodak EasyShare C703 Digital Camera
The camera repeatedly tells me to format the 4GB card that I have inserted. It reads, "formatting," then returns to "Memory card requires formatting." Selecting "Continue"...
The DX6440 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use cards 2GB and smaller.
Dec 27, 2010 | Kodak EasyShare DX6440 Digital Camera
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
LEXAR 4GB SD MEMORY CARD FORMAT??
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Nov 29, 2008 | Kodak EasyShare CX7300 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
