Question about Maytag Neptune MAH5500B Front Load Washer
The inside rim when you open the door of the washes is all moundy. Can it be replaced?
    Champion:
  • 245 Answers
Yes
Posted on Aug 19, 2010
My bosh classic xx 1400 express washing machine door has came off. is there any way of getting it back on ? thanks wendy
you can buy a new rim easy to fit is it the inner or the outer rim check before you buy ???? you will need the enr no
Jun 24, 2012 | Bosch Exxcel WFX 145S Front Load Washer
Where can I download a manual for Whirlpool AWM321
You could go to whirlpool.com and click ower center and download a maual for your washer,i tried that but it says the model number couldn't be matched
The following is from the whirlpool website and it shows where to find the model#
Please find the type of appliance you are interested in and click on the link to view the likely location of the model number plate on that appliance here is where the model# could be found
Type of Appliance Model Number Plate Location Range Inside oven drawer, on oven rim Wall Oven Inside oven drawer, on rim Cooktop On underside of unit Microwave Inside microwave, on rim Dishwasher Inside dishwasher, on rim Refrigerator Inside refrigerator, on wall Trash Compactor Inside, on rim Food Waste Disposer Attached to the unit Washer Beneath washer lid, on tub rim Dryer Inside dryer door, on rim.
Jul 29, 2011 | Washing Machines
I have a 1994 ford aerostar. the sliding door will not open. how do you free it up and repair the locking mech
Remove the screws from the inside plastic rim around the windows and the inside panel on the lower portion of the door.There is a square hole in the upper portion of the inside of the door. Reach your hand inside and you can feel a metal rod wrapped in material. This is the actuator rod for the sliding door latch. Grab it and push it backwards. You may need to open the sliding window, stand out side and using your right hand reach through the open window, into the square hole in the door and grab the rod this way. Push back on the rod like crazy. Use vice grips it necessary. Work on this rod until the door opens, kick the door from the inside if necessary (use a friend). Once the door is open replace the door latch, available from Ford for about $35, replace the Torex bolts with 6 x 1.0 x 45 mm metric bolts, 10 mm head. You may need to use a torch to get the original bolts out of the old latch. With a new latch you can open the sliding door by just using your pinky finger.
Good luck.
Jul 10, 2011 | 1994 Ford Aerostar Extended
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Hi dear i have lngersoll deatbolt rim lock front of my door. i wanted to replace the only rim cylinder but i dont khow how to remove old rim cylinder. also can i use other company,s rim for my old...
The lock is removed after you undo the bolts on the inside The whole cenre should slip out. I doubt you can use another brand in the rim that will mate up with the equipment inside the house side of the door But you can completely replace it in the alreaqdy made hole
Aug 30, 2009 | Deadbolt PFK Touchpad Electronic Lockset
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Maytag Neptune MAH5500B Front Load Washer Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
