Question about Pioneer PL-990 Turntable
Turntable will not turn. - Pioneer PL-990 Turntable
    Champion:
  • 222 Answers
This is a belt driven turntable, check the belt if it is loose replace it with a brand new one, you can buy one at partstore.com
Posted on Aug 20, 2010
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Apr 20, 2009 | Philco (R) Classic Turntable CD Shelf...
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
Turntable won't turn
The turntable probably isn't on the spinny thing and that is what makes it turn- try lifting it up and putting it back on.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not turn round
Have you put the drivebelt around the motor spindle - the instructions don't make it too clear. The belt is already on the underside of the turntable, you just need to put a finger through the hole in the turntable, pull the belt out and hook it over the motor spindle. After that, if you've pressed the power button (back right), you should see the 33rpm light come on. If it's on, press either of the 2 big buttons on the left hand side and the motor should turn. You can check by looking through the hole in the turntable & see if the motor spindle is turning. If none of the above work then you have a faulty unit.
Jan 01, 2009 | ION Audio iTTUSB Turntable
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
Pioneer PL-990 Turntable Logo
171 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
