Question about Westinghouse SK-32H240S Television
Westinghouse sk32h240s does this model have a digital tuner or do I need a coverter box. I have a digital antenna connected directly to the tv and channel seach produces no channels both on cabel and antenna seach
SOURCE: Westinghouse LTV-19W6 TV Won't change channels
I had the same the problem.  My tv would not change channels.  I had to run the tv through my dvd player to be able to view my cable channels.  The one solution listed did work for me.  Set your source to tv...press menu on your remote control...go down to the 4th icon...press the right arrow...move down to CH Auto Scan and press the right arrow.  The tv will scan for channels and once complete I was able to change channels again.
Posted on Jan 10, 2009
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
  • 718 Answers
SOURCE: No pictrue
Is the LED light purple ?
I have only read bad things about this model. Here are some of the things I have come across. Try this first. With the TV on, unplug it, wait a few seconds an plug it back in. You may also turn off the energy saving mode.
Beyond that the problem could be one of four problems;
1) Bad cable connection to inverter board. Make sure all cables are firmly seated.
2) Inverter board is bad.
3) Power to inverter board is bad.
4) CCFT(cold cathode fluoresent light) has problems.
Posted on Mar 12, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
  • 14 Answers
SOURCE: unable to program cable channels on westinghouse lcd tv
There is some system reset to set the tv back to default settings. Also some boxes are picky and want the tv to be on chanel3 or 4 for the scan.
Posted on Jun 26, 2009
My brand new westinghouse TV will not pick up any digital channels. Any help?
read the user manual
check that you have the correct antenna for your area
talk with the technicians where you bought the unit
contact the manufacturer on a contact them phone number and discuss the problem with their technicians
Dec 16, 2015 | Westinghouse Televison & Video
IDo i need coverter box for Toshiba 36A40
Short answer NO. You'll need a converter box since the tuner in the TV will not get digital TV signals.
http://www.ehow.com/list_7492878_toshiba-36a40-specs.html
Sep 25, 2014 | Audio Players & Recorders
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 | GPS
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
I don't have signal on my tv and there are no program's to watch as they are all blank. Is just a brand new tv I bought like 2 days ago
What make and model of TV do you have? What is your signal source (OTA (indoor or outdoor antenna), cable, satellite)? How is the TV connected to the source?
The model is important since some "TVs" are actually only monitors and do not have tuners. Then you need to connect to a set top box to watch anything.
Assuming the TV has an ATSC (digital) tuner for OTA, check that your antenna is pointed in the correct direction for the stations in your area. Use antennaweb.org or tvfool.com to identify the direction. Antennaweb assumes an external antenna and gives a very conservative list of stations. TVfool tells you the type of antenna needed to get any station (assuming no trees or tall buildings that might block the signal). Depending on your TV, you will need to enter the menu in order to correctly set the incoming signal type and scan for channels. Digital signals are either enough for the tuner to interpret or not available. If your signal is split between several TVs you may need an amplifier to get enough signal. Sometimes, the amplifier may fail and filter out all stations in certain frequencies. (Older TVs often only had a NTSC tuner; there are very few NTSC stations still broadcasting. They are low-power and thus you may not be able to watch them if they are far away.)
If you have cable without a box, which type of cable signal is coming in? Digital cable is QAM and not all TVs have a clearQAM tuner (that reads the unencrypted signal).
If you are using a set top box, make sure to set the TV to the correct input (HDMI, component video, composite video, coax and the correct number if there are multiple inputs). Make sure that the box is also on. If the set top box requires the TV to be set to a specific channel (3,4,60), make sure to go to that channel.
I hope this helps.
(For the US, the digital OTA tuner is ATSC and QAM for cable. In other countries, different signal formats are used.)
Oct 22, 2012 | Televison & Video
With the hd52w59 do you need a coverter box to hook up a digital antenna??
No this tv have a digital tuner inside.Tv don't require a digital converter box to get a DTV free air signal.Just hook it up with a good digital antena and rescan to find free air DTV,will able to get it.
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
