Question about Kenmore 24 in. 16302 Built-in Dishwasher
My dish washer keeps running...for hours. It usuallt stick when the dial is at the 7 on a clock. Today we got it to continue through the whole cycle but now it does not drain. Any suggestions?
    Scholar:
  • 93 Answers
It sounds like a problem with the timer mechanism itself. Make sure there is nothing restricting the dial from turning (sticky gunk behind it, etc.).
Posted on Aug 19, 2010
We have an LG electric dryer Model number DLE2050W and when I turn it on it starts and runs but after awhile the illuminated board goes black,but the dryer continues to run. But it will not shut off.
I have an educated guess for you. A part of each control of a washer and a dryer is a little electric "clock". Those things can fail. I sounds like you may have a timer clock that is sticking and not advancing.
These " clocks" are a part of the times, and are not sold separately.
One way to possible tell would be to put your ear to the area of the control panel where the timer is and listen. Most of those "clocks" tick, and you can often hear them, or you can watch the dial, and it should advance with a click every so often.
Be blessed.
Feb 13, 2014 | LG Dryers
Everytime I put the pre-sets for the timer, it does'nt keep time. COuld you assist me or provide me with someone who can repair?
I can assist you.
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
The 'pre-sets' are confusing.
Do you mean tabs or trippers?
Tork 8601 is a 60 minute cycle timer.
The dial should make 1 full revolution each 60 minutes.
Trippers or tabs located on dial are pushed up or down to set on-off schedule.
If dial is running slow, then clock motor has gone bad.
If dial is running on time, then trippers are worn down or timer parts are worn down.
Either case when timer stops functioning, buy a new timer for $110.
If the clock motor was available, you'd probably spend $60 for the motor.
http://www.farmerboyag.com/time-clocks/23080024.asp
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Same Intermatic timer is C8865 for $88.35
http://www.amazon.com/Intermatic-C8865-1-Hour-Repeat-20-Amps/dp/B000GHKO8K
Jul 18, 2011 | TORK Variable Cycling Timer 8601
We have installed GM40 time. which control shaft on / off cycle i.e 4 hours on / 2 off. i checked selector switch postion, i.e continuous on (upper position) and continuous off (lower position) in this...
I have GM40 timer sitting in front of me.
I cannot understand your question because I do not know what the 'control shaft' is.
If you mean the black-colored FM1 clock dial with captive trippers, then this dial is supposed to rotate continually as long as timer has power.
http://waterheatertimer.org/images/FM-1-Grasslin-Intermatic-20.jpg
Grasslin/Intermatic GM40 page
http://www.intermatic.com/products/grasslin/electromechanical%20time%20switches/multi-voltage%20time%20switches.aspx
The manual says quote:
With the manual switch in the middle position, the GM40 is in automatic mode and will switch at the programmed times. In the upper position "I", the load is permanently ON. In the lower position, "O", the load is permanently OFF. End quote.
In any switch position, the FM1 clock dial will continually rotate.
If your Load does not turn on-and-off according to the trippers set on FM1 clock dial, then 1) wiring is suspect or 2) if dip switches are not correctly set before applying voltage, and timer could be damaged.
The timer arrives with dip switches pre-set for 277Volts.
You can also manually rotate clock dial clockwise to observe when the load turns on-off.
Add a comment and give more information.
I would like to know what the 'control shaft' is, and what voltage you are using, and what dips switch setting you have, and which wires are connected to each terminal.
Apr 13, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Water does not drain
either dial has went up or the pump has
Jul 01, 2009 | Washing Machines
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Will not run continuously!
Either you have a faulty module or timer switch the dial used to set the wash program. If for any reason it ha been turned in the wrong direction your machie can behave exactly as you describe. Hope this helps.
Jul 29, 2008 | Kenmore 24932 Top Load Washer
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Sep 07, 2007 | Ariston Technologies AW125NA 13 lbs. Load...
Kenmore 24 in. 16302 Built-in Dishwasher Logo
96 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
