Question about Smeg Refrigerators
My wife punctured the freezer whith a knife, can it be fixed
    Champion:
  • 245 Answers
JB WELD
Posted on Aug 19, 2010
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
On puncture point there will be apply gas welding
Posted on Aug 07, 2015
Technician will weld the punture or will apply some sort of dpoxy magic steel on it and will refill new gas in refrigerator and all will be fine
Posted on Jul 15, 2013
  • zafar Jul 15, 2013
    technician will weld the punture or will apply some sort of dpoxy magic steel on it and will refill new gas in refrigerator and all will be fine
I put a knife puncture in my tru cold refrigerator, freezer combination in the freezer part
Is the freezer/ refirdge still working? If everything is still working, then the puncture did not cause damage to any great extent. Just place a piece of aluminum duct tape of the puncture hole. You can purchase the tape in a hardware store or Home Depot/Lowes, in the plumbing, heating dept. If the refridge is not working, then there is a major repair to be done.
May 05, 2014 | Refrigerators
Freezer panel not working
Sounds like someone tried to "defrost" it with a steak knife...
The government employees in the highrise office buildings where I once worked used to do it all the time.
The aluminum evaporator is nearly impossible to repair and the repairmen will tell you it's cheaper to replace it.
Apr 13, 2014 | Sanyo 4.4 cu. ft Counter-High...
Like many folks before, I have punctured my freezer while defrosting it with a knife (yes, stupid thing to do). The coolant is hissing out of the freezer right now. The question is: will the fridge still...
Once a hole allows freon to escape, it's usually best to replace the product, as moisture will enter the sealed system and contaminate everything.
Dec 10, 2017 | LEC Freezers
How do i defrost the freezer do i smply turn it off??
Yes... the best way is to empty it out and just turn it off leaving the door open...
A hair dryer or heat gun will speed things up but do not use a knife or ice pick...you can puncture the coils and kill the freezer...
heatman101
Jul 12, 2011 | Hotpoint Freezers
I punctured the freezer with a knife moving ice I put silicone on the small hole will the freezer work
as long as you did not cut a wire or refrigerant line it will be fine.
Aug 08, 2010 | Refrigerators
My fridge and freezer are not getting cold enough. What could be the problem
check your compressor, see if its working. If it isnt it may be due to thermostat not making contact or starter relay faulty. if compressor is running though it will be most definitely short of gas. Check for puncture in the freezer section,knife is the worst tool to use for defrosting your freezer.
Dec 02, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Punctured freezer wall in dormer fridge
Usually try not to even answer these questions because anything less than a FixYa drops my rating, so maybe don't bother rating, OK?
Yes, it's a goner. Repair would cost more than a new unit.
Oct 27, 2008 | Master Bilt Indoor Step In Cooler 70""W x...
REPAIR or REPLACE?
OMG ROFL!!!
Well... here's an idea.
Drill a 1/2 inch hole where you punctured the wall of the freezer, make sure you don't hit the coils. Then goto lowes/home depot and get that expansion foam that is used to insulate windows and holes in houses. Grab a razor blade and scalp off the excess after it's dried. Now cover the foam on the inside of the freezer with 2 part epoxy or "shoe goo" or e6000 (these are the toughest glues I have ever used) which is available at a hobby shop. Make sure you do a test with the foam and the glue on cardboard first to make sure the glue won't eat at the foam.
Are you sure you punctured the coil? If you did you can goto an auto part place and ask for a compression fitting (most commonly used to repair brake lines on cars) for what ever tube size the coil is, use a fine ruler is the best. Then you can repair the coil by using a pipe cutter to cut the coil and put it back together with the compression fitting. Now call the appliance service guys and have them come out and recharge the system.
Fixed, total cost... about $50 bucks
Other solution, replace entire fridge, total cost $$$$$
Sep 04, 2008 | Thetford Norcold® Model DE0061
Fridge freezer
did your friend use a knife to prize off lumps of ice? i bet he/she did and has punctured the evaporator. if so, not repairable
Jul 04, 2008 | Zanussi Freezers
Refrigerators Logo
1,129 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
