Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Freezer is freezing but refrigerator isn't cooling
    Novelist:
    Champion:
  • 266 Answers
Check and see if the fan is running in he freezer. The fridge side steals air from the freezer via a small duct that is controlled by a dial in the fridge side. If the fan is working see if the freezer is getting ice or frost build up in the back. If it is you may have a bad defrost timer or a bad heating element both of these can be checked by the home owner. The defrost timer is usually located in the top of the fridge where your controls are at or in the center top if you have a light and controls there. Take the plastic housing off (sometimes metal on older models) the timer will be a plastic part with a metal round motor on it. It will have a wire plug with several wires running to it. On the case will be an access hub that a screwdriver will fit into. Turn it you will hear audible clicks turn it slowly until the fan and compressor shut off it will now be in defrost mode. Be careful it is easy to go to far if you do just continue to turn it until you click into defrost. Now wait approximately 3 minutes and you should hear hissing and cracking sounds coming from the back of your freezer. This is ice melting. If you do replace the defrost thermostat. If not the heating element needs to be replaced it is in the back of the freezer. Take the rear shell out of the freezer you will first need to remove the shelves/icemaker ect... Behind the shell you will see a coil made of aluminum and near the bottom a 12 to 16 inch black tube with a wire on each end this is your heating element and one end of the element will be a defrost limit switch. This is about the size around as a nickle and about 1/2 inch thick it has two wires one to power and one to the element. Replace both the element and thermal limit. You can use **** connectors or twist type caps to put the wires back together just use 3M electric tape to seal them. You can also buy liquid tape at a hardware store you paint it on like paint its great. I hope this helps and good luck. Remember to unplug before you start cutting wires. good luck
Posted on Aug 19, 2010
I have a Whirlpool Refrigerator model # ET21PKXGW01 the freezer isn't freezing and the fridge isn't as cold as it should be (milk went bad). I did notice right before it stopped freezing/cooling I...
hey how r u today im no specialist but it sounds like a condensor fan if that fan goes your fridge will overheat not allowing proper freezing and or cooling. my family had the exact same problem and my dad was a appliance repair man so he knows about everything when it comes to this stuff..well hope i helped and congrats i hope u and your fiance go far. Jacob Winkler
Jul 16, 2012 | Refrigerators
Refrigator not cooling.
Are you filling your freezer to full that it isn't able to cool? Maybe you just need to have it serviced filling it with Freon.
Jul 09, 2012 | Refrigerators
Frig keeps freezing even though it is turned down completely
First check that all the cooling tubes are open between the freezer to refrigerator. If one plugs up, then all the cold is focused on one spot in the refrigerator. If that isn't the problem, then replace the refrigerator thermostat.
Jan 18, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
Freezer side seems to work but the refrigerator side isn't
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 11, 2011 | Maytag Refrigerators
I have a side by side Frigidaire model KSSS42QDX02 the freezer isn't freezing and the refrigerator won"t cool without the freezer being turned on...HELP!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Frigidaire FRS3R5EMB Side by Side...
The freeze has ice build up on the back wall and the temperature isn't cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
