Question about Asko W6021 Front Load Washer
The door on my asko w6021 wont close
Hello
I have had my asko in storage for 2 years and when I connected it up last night it did 2 washes and now when I tried to do the next was the door wont close. I have checked everything, but it wont close, so the machine wont work.
thanks Roslyn
Hello
Well I'm sure you have power on machine if not check fuse located at rear of machine below lip.
Next step remove top cover a cheap saftey screw driver set
will do trick not standard drivers.Electrical drawing is located
inside,Photo copy,now locate a cheap multimeter for testing,
don't worry it's not rocket science.Look closely at cables notice all cables have numbers printed.If PWR lamp above switch is on proceed as follows.
Remove power from machine & test on the Ohms scale between
E111 & E113 if you have resistance great i can't remember value! Now put a bridge wire between E121 & E111with closed door should lock when machine is turned on ,if not you can test between V Volt scale ac & you should read about 30 Volts ac Between E113 &E111when you press door release button on front of machine.
Note the switch LB in drawing represents front door you can also
check across this on Ohms scale with no PWR.
Regards
Posted on May 06, 2008
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Door wont open and wont turn on
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 18, 2011 | Asko W6021 Front Load Washer
I'm trying to start the asko washer for the first time and I can't get the door to lock. the start button is blinking??
HI there, the door on my front loader was very hard to close, but the service people told me to close it really hard - slam it! and it has been fine ever since.
Jan 02, 2011 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
Asko front load washing machine
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
May 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Jun 11, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
240 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
