Question about Danby DDR4010E Dehumidifier
Unit not taken any water out of the air. - Danby DDR4010E Dehumidifier
    Master:
    Sergeant:
  • 449 Answers
Eather the unit is not working or you have very little humidity inthe air
Posted on Aug 19, 2010
Can it be used in toilet ? The walls are damp due to basement
It can be used in a bathroom in a safe place. It might taut of the bowel and drain traps but should not take any water out of the tank an air conditioner is a big humidifier so if you have an A/C you already have some moister being taken out. And a heating unit takes even more out then the A/C so I would say no problem.
Aug 28, 2014 | DeLonghi Dehumidifiers
I have a Zenith dehumidifier P/N 3850A20500H. It was working, and now its not. I cleaned the air filter, and the fan spins just fine when I spin it by hand. Any suggestions? Thanks, Gary
Gary, if it's not collecting condensation, there are 5 basic, yet solvable reason s for this. One you have already taken care of - cleaning the filter.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
set the humidity extraction level knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 08, 2011 | Goldstar DH504EL Dehumidifier
My GE basement dehumidifier is overheating. The bucket still collects water and the fan works, but the unit is putting out alot of heat. My dad is visiting and has taken the whole thing apart. Any...
Yes, the first suggestion is I hope your dad can get it back together without any parts left over (LOL). Over heating is generally caused by an clogged or dirty air intake filter. Simply removing it and vacuuming it or if it's really dirty, washing it in warm water and mild dish washing liquid will clean it. Rinse it thoroughly, shake off excess water and allow to dry completely. Never operate the unit without the filter in place. Doing so, can damage the unit.
Getting back to the heat for a moment and where you're using your dehumidifier. Dehumidifiers do generate heat, it's not abnormal. Operating it in a basement can cause it to over heat. This happens because the air temperature at floor level is colder than at shoulder level. Dehumidifiers struggle in temperatures below 65 degrees F (unless you have a Low temp unit, designed for basement applications). Raising the unit up off the floor, on to a sturdy table, counter top, etc, that an handle the weight of the unit, plus a full bucket of water, will generally resolve the problem.
Actually, a basement application , higher is better.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | GE AHG40LJ Dehumidifier
Unit is not collecting any water in bucket (it has been set at 35%) unit also seems to be shutting off to soon in the '4hr' timed cycle
There are 5 basic things cause the problem you're having. Number 1, you have already taken care of.
level
problem.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 21, 2011 | LG LD40E Dehumidifier
My unit runs for about 10-15 minutes then shuts off. I cleaned my filter so that is not the problem.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. (# 2, you have already taken care of)
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, turn the knob to Maximum
in basement application . Raising the unit up off the floor,
problem.
Jul 13, 2011 | Goldstar DH2510A Dehumidifier
The dehumidifier is not collecting water in the basket. I have cleand the filter and even taken off the front cover to clean inside. Any other ideas to get this back working?
The lack of water in the bucket, may be a result of the humidity setting on the unit being to high. Try setting the level at 45% or lower. Also, be sure there's adequate air flow around the unit itself. It should remain a minimum of 12' from a wall or furniture. 24" is better.
If the above doesn't solve the problem, try this at home test. Place the unit in the bathroom, turn it ON and set the level as low as possible. Turn the shower ON hot enough to generate steam. Do not turn ON the bathroom's exhaust fan. As you exit the bathroom, close the door. Wait 15 to 20 minutes, before returning to the bathroom. When you do, turn the shower OFF and allow the unit to run for several more minutes. Then check the bucket for water. If there is any sign of water in it, it's working fine. It was probably a case of the humidity level being set to high the first time.
If there was no water in the bucket, the refrigerant gas in the cooling coils and the compressor may need recharging.
Hope this helped your to troubleshoot and solve the problem. Please let me know. Thanks.
May 22, 2011 | Haier 45-Pint Dehumidifier
My whirlpool dehumidifier fan runs, but no water is being taken out of the air; cleaned the filter and still no change; dehumidifier was purchased in August 2008.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
LG LHD45EL Dehumidifier - The dehumidifier runs continuously, but very little moisture is taken out of the air. There is only about one quarter of a tank of water after running continuously for 24 hours in...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 12, 2010 | LG LHD45EL Dehumidifier
Top of dehumidifier is very hot to the touch, filter is clean don't know what to do, afraid to put it on in case of fire.
Are you running it in high ambient temperatures?
Can you see any condensate(water) on the coil?
It may be that it is running above it's temperature range. A dehumidifier has two coils(radiators if you like). One gets cold, the other gets hot. The first one renoves the moisture from the air, this is the evaporator and is cold. The heat taken from the air is absorbed into the refrigerant and is given back to the air when it passes through th other coil, the condensor which is hot. The refrigeration circuit itself produces heat. This heat plus the heat absorbed from the air has to be got rid of. If the ambient temperature is high, the condensor will have trouble getting rid of the heat from the circuit. This can cause the case to feel hot to the touch. Assuming you don't have a refrigeration leak, it may not be worth running the unit if it is not removing moisture from the air. Is any water being dropped into the bucket? If it isn't, all you are doing is wasting electricity.
Aug 15, 2009 | Midea MDC-45AE Dehumidifier
Dehumidifier running but no pulling any water from the room
Check float switch some of the unit have afloat switch hooked to the unit. Next check the condenser coilsThey do get stopped up cat,dog hair and just plain get dirty vaccuum them out and try unit. Rusty
Jun 12, 2009 | Bionaire BDQ24 Quietech Dehumidifier
Danby DDR4010E Dehumidifier Logo
112 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
