Question about Homelite Leaf Vac Attack
Homelite Vac Attack UT08107 My gas kept leaking out so I replaced the fuel lines. It still is leaking. It looks like it is coming from the carburetor.I took the cover off and there is not a gasket. What are your thoughts about this?
MNfisherman
  • 11896 Answers
SOURCE: need to know the right gas to oil mixture for a Homelite Vac Atta
All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils
Posted on May 22, 2009
SOURCE: How do I switch my Homelite Vac Attack II to a
Here's an online manual you can download to walk you through it.
http://lawnandgarden.owneriq.net/manuals/mfg/homelite/vac_attack_ii_blower_vacuum_zr08107.html
Hope this helps.
Posted on Jul 05, 2009
canbruce75
  • 1776 Answers
SOURCE: what is the gas ratio for Homelite Vac Attack II
The mix that I would use is one ounce of two cycle oil per quart or four ounces of two cycle oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Posted on Aug 31, 2009
Testimonial: "thanks. "
  • 5 Answers
SOURCE: Need a user manual for Homelite Vac attack 2
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
rwvanlue
  • 486 Answers
SOURCE: i have the homelite Vac Attack 2, i'm having
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Posted on Nov 11, 2009
I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Nov 02, 2010 | Homelite Garden
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
#2 senerio
1) spark plug
Remove Carburetor
Nov 09, 2009 | Homelite Leaf Vac Attack
Does this blower use 2 cycle mix; I have a homelite vac attack II 200mph blower and it is having trouble starting
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Oct 12, 2009 | Homelite Leaf Vac Attack
Homelite Leaf Vac Attack Logo
177 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
