Question about Dishwashers
Hotpoint dishwasher bf1620 - 1st light indicator (heavy soil)flashing. information from hotpoint and manual useless
  • uncle_ceps Jun 02, 2008
    I have exactly the same problem.
    Any ideas?
  • chriskat498c Jul 05, 2008
    hi all, the problem i am having is that my hotpoint BF1620 is not producing hot water during any cycle and when the cycle is finished the eco cycle light is blinking. i would really appreciate any help, thanks in advance.
I have had this problem twice now and the problem is water in the drip tray. The guys at Hotpoint eventually told me what the light meant as he wanted me to have an engineer and the manual does not say.!!
So if your up to it uplug from the mains and turn water off to the unit, pull the dishwasher out and lay it on its side (first putting down towels as the water will spill out depending where it was in the cycle when it stopped).
At the bottom of the dishwasher along both long sides there are 6 screws ( 3 each side) remove these easy peezy. Gently remove the tray/plate as it has connections there. You will probably notice the water on the tray or in the gubbins (nice word). Get a dry towel and dry what you can not forgetting the tray itself. Then and this is the important bit, use a hairdryer on all the gubbins and the metal insides DONT FORGET TO DO THE TRAY ITSELF. Take at least 20 mins to do this getting everything completly dry.
Then put together again, stand it up gently and try it.
You may or may not notice the water in the drip tray or on the gubbins, it does not take much for it to stop working.
This has worked twice for me. Also with the help of the internet and costing me £5 I was able to remove broken glass from the drain pump. I have saved myself a fortune.
This is from a woman who knows NOTHING about this sort of thing so if I can fix it anyone can.
Power to the girls !!!!
Posted on Apr 25, 2009
Hello!
I found out from hotpoint that the first flashing indicator means that the 'float switch' has been activated meaning that the base tray 'may' be leaking. I don't know whether this is a tactic to get their repair man out to fix it.
I was wondering whether there is a way to reset the switch and try re-running a programme as my base tray doesn't seem to be leaking.
I hope this helps a bit
Posted on Jun 03, 2008
Posted on Jun 02, 2008
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 | Dishwashers
I have a Hotpoint SDW 60 problem! The dishwasher starts and goes through pre-wash but stops with just the 'Delicate' light flashing. Does anyone know what the problem may be?
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Jul 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    Delicate light flashing will not dry
    Post more information about your problem if you need more help....
    Good Luck!!
    Thanks
    Aug 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
    The Heavy Duty and the Daily Cycle lights are
    to better assist you can you provide me with the ERROR code, if is any.
    Thank you
    May 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
    The program light goes off and the BF162 doesn't start...
    When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
    Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
    Hotpoint fdw80 dishwasher
    Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
    Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
    Hotpoint Dishwasher BF1620
    ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
    Mar 21, 2008 | Dishwashers
    Hotpoint aquarius dishwasher
    Oversudsing
    This can be due to using a laundry or handwash detergent instead of a specific dishwasher detergent instead. It could also be due to excessive amounts of rinse aid in the dispenser or certain food soils that contain a high level of protein such as eggs.
    Oct 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwashers Logo
    2,111 people viewed this question
    Top Dishwashers Experts
