Question about Samsung Televison & Video
Won't stay in focus? keeps getting red out of focus.b
  • Samsung Master
  • 8,457 Answers
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the covergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Samsung/Akai tvs used the same convergence board.Or the shop will cost u $300-350 for parts and labors.
Posted on Aug 19, 2010
Ax550 won't take picture, shooting mode icon outlined in red.
you can try to format the memory card and then reinsert it to your camera again to try.
Check whether your camera is focusing or not. unless it focuses and its locked , the shutter wont get released.
it can be due to improper light or distance of the object, or even problem with your camera internally.
check if there is any noise while focusing,a jam can also cause such a result for some cameras.
Feb 04, 2013 | Fujifilm FinePix AX550 Digital Camera
Car starts but won't stay running
Check on your inline fuel filter. If this clogged the fuel pump cannot pump gas through it to get to motor.
Jan 01, 2013 | 2003 Ford Focus
Air conditioning won't stay on
something wrong with your air conditioning,you can get j2534 to diagnosis of cooling electronic.
Jul 02, 2012 | 2003 Ford Focus
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
My EFS17-85mm lens AF cannot focus steadily keeps on moving
I don't know your level of expertise...
Here goes. Your AF sensors in the camera need a certain amount of light to confirm focus. F/4-5.6 is a little dark, but under normal daylight its ok. Under darker conditions, it just can't get enough light to confirm focus, and it just keeps "hunting" for the correct focus. Using a teleconverter makes it even worse. The red focus assist beam sent out by that external flash unit only helps focus within about 20 feet.
Solution? Find a place with more available light, or buy one of the lenses with f/2.8 rating.
Dec 29, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Ford Focus T Reg (UK) Key Fob Not Working.
it might be the 60 amp black fuse my partner just said
Apr 13, 2009 | 2000 Ford Focus
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
